Uniden DCT646-2 Cordless Phone Logo
Posted on Jul 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to check my answering machine messages remotely, when away from home
Anonymous
Level 2:
  • Expert 88 Answers
  • Posted on Jul 27, 2009
Anonymous
Expert
Level 2:
Answers
88
Questions
Helped
23832
Points
259
Get a ethernet usb connector and a mobile broadband dongle, use the dongle in your laptop when you are away and use the usb ethernet connector on the phone base, it should have a port somewhere.
3helpful
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
3helpful
How do I retrieve messages when I am away from home? Model # EXA15580
Remote access away from home first you must enter the PIN code: 1) Enter the Answer Setup menu, and then the Security Code submenu 2) Enter a two-digit PIN code (01-99) using the number keypad (0-9). 3)Press OK
You can operate your answering system from a remote location using any touch-tone telephone. 1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps. 2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds 3)listen to the instructions from there (to play incoming messages, press zero-two)
1helpful
Hi. I have not ever remotely connected to the answering machine and do not know the default password. Can you supply that and how to do it.I am away on a business trip and want to check my home...
The default security code is 500. To check your messages, dial your number, when the answer machine answers dial your code, the number of mesages will be annonced and then it will begin playback of messages. If the announcement continues after entering your code, wait for the announcement to end or press # to end the announcement, re-enter your code to listen to your messages. I've included a link where you can download the manual, to download it click on the pdf file then you will need to rate the product or click on security code(rating the product is quicker).
http://safemanuals.com/user-guide-instructions-owner-manual/AT%2526T/1739-DIGITAL-_E
How can I receive remote messages
When you are away, you call your number. After the answering machine asks you to leave a message, punch your code and listen to the instructions (hear new messages, hear all messages, erase message, de/activate answering function, etc.).
Hope it helps.
Remote operation
Here it is.
To erase messages.
Can't retrieve messages from home answering machine when away
Indeed... YES Wrinkles3,
I can help you a couple of ways...!!
First and FOREMOST...
Go in NOW and edit your PERSONAL & PRIVATE
INFORMATION...
Right now every WACKO on the internet
Knows your NUMBER & INTERNET identity...
(and probably your DEFAULT "pin" code)
You just gave everything ELSE needed))
With very MUCH ease I could enter your home phone...
MONITOR your rooms... Take your messages... (etc.).
Find your Name, address & track family members))
You are seconds away from some
SERIOUS IDENTITY theft issues...
Never post personal information on the internet
>> (seriously).
Generally ...
You need to clear off that INFORMATION
and get paranoid... EDIT it off NOW...!!
On to your question: Your Owners Manual
(please ... oh please HAVE a REAL pin number).
Your page 31: tells you (& the WORLD)... How to
operate YOUR PHONE:
Uniden EXS 9950 Owner Manual Remote Access Away From Home
ELSE
call UnidenDirect at 1-800-297-1023 (your page 36)
7:00 am to 7:00 pm CST
Uniden EXS 9950 Owner Manual Specifications Base Unit
Pretty please... a little caution would go a long way..!!
Carnac the Magnificent
3answers
Uniden telephone answering machine
Replaced my battery for my Uniden 900MHz phone and lost my instruction book..Need to program it again for memory numbers.
How do I do that?
3helpful
Att 1717 answering machine manual
Most manuals are just a Google search away. "att 1717" returned the following result.
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=162
37helpful
2answers
Uniden answering machine model 900MHZ
Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
* For the Repeat a Message function, press 0 then 1 within about four seconds to
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
REMOTE ANSWERING MACHINE
On my Uniden (not sure the model) I press 0 during the outgoing message and then my 4-digit pin.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
