Question about Linksys Wireless-G WRT54G Router
Laptop will not connect to my wireless setup
It says that i need to change my security settings, cause it is not compatible with the wireless network. how do i do that?
    President:
  • 2,559 Answers
You need to set the security on the laptop to the same security on the router,Just open Internet explorer and type 192.168.1.1
Enter the login and password for your router. The default login is blank and the password is admin
go to the security settings and set it up the way you want it,It must be set up the same on the laptop so write down t he settings if you need to.
Click save
Then go to the wireless tab at the top and turn on Allow wireless connections
or go here for more details http://www.linksysbycisco.com/US/en/home
Posted on Jul 27, 2009
  • 21 Answers
If your wireless router is a linksys, try resetting it. There is a reset button on the rear of the router. Look next to where the ac power cord meets the router, there should be a small, black circle the size of a pen-tip. Press this button when router is turned on. This will reset the router to factory default settings and your router will be in "open" mode meaning anyone can use your router without a password/key. If your laptop get's online after this, you should change the settings to set-up a webkey or password.
I cant add roku as a new device to my laptop and the microsoft will not let me updated
1. Enter your wireless router setup page using a computer that is hardwired to your router.
2. Go to your Wi-fi protected setup options and disable Wi-fi protected setup (WPS). Apply this change.
3. Go to your wireless security settings and select your desired WPA or WPA2 security mode and your desired password (psk). Apply this change.
4. Go to your Channel and SSID settings tab and RENAME YOUR SSID. Apply this change.
5. Now view your wireless networks on your upgraded Windows 7 machine.
6. Select the newly named network.
7. Select "connect" and enter your new passkey/password.
Let me know if this works for you.
tony
Feb 10, 2013 | HP Pavilion dv7-1240us Notebook
How to change security setting to secure
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. These settings prevents unauthorized access to your wireless network and Internet. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 25, 2012 | Linksys Wireless-G WRT54G Router
Setup didn't work, "details" section on network
Win7 will connect without any problems, but win vista will not get connected to the network...
You can update the drivers for wireless adapter in vista laptop, it will get connected...
If it still not getting connected then change the security settings on your router to 64bit WEP... (Initially it will be in WPA)
disabled the WPS (wifi protected setup) in the router...
change the ssid in the router...
Now try to connect to the new wireless network...It will work perfectly....
click here to configure the wireless part of your belkin router...
Any issues call 18002235546 ( 24/7 )
Feb 06, 2011 | Belkin Play N600 Wireless Dual Band Router...
2.4GHz Wireless Lan And 5 GHz Wireless LAN
this is usually caused by your router and your wireless network card are not compatible... you need to purchase as well cisco wireless network card adn tehn when you press your wireless security on the router, it will automatically apply all security protocol to the connection.
if you do not want to purchase new card, you always can setup these devices manually,
connect to the router via rj45 cable, establish what protocol, security and transmission method/frequency you will be using, write that down, disconnect the cable, enter your wireless network card settings and apply same settings to your network card, this should solve the problem.
as you did not stated what operating system you are using and what card is in your computer, this is unfortunately best advice which can be given.
how to set up your router, you have downloadable pdf file on linksys site.
Jul 28, 2010 | Linksys Wireless-G WRT54G Router
How do I secure my Dynamode BR 6004 WG1 Iam a
To secure your wireless network from unauthorized access, you need to at least configure the wireless router with encryption, and the SSID, and change the router's default login password.
Please follow these instructions :-
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Jul 23, 2010 | Dynamode (R-ADSL-C4-W) Wireless Router
Not wep compatable
what is not compatible to the WEP. is it computer or the router ?
All the routers are compatible with WEP.
If you want to change the security type, you can change it to WPA. For this you will need to access the router set up page. Is there any computer connected to the router ? If not then you will need to connect the computer to the router . open the set up page of the router and change the security mode. also change the network name.
Once you change these settings , you will need to connect to the new wireless network on all your computers and other wireless devices in the network.
Click Here for more information about the router and networking
Feb 08, 2010 | NetGear WGR614 Wireless Router
Win xp desktop connected to wrt54gs router wants laptop running win 7 to connect wirelessly
We need to know the wireless settings on your router before configuring the laptop.
To check the wireless settings, access the setup page of the router by using the desktop's internet browser. In the address bar, type 192.168.1.1.
Default login is: leave the username blank, then the password is admin.
Once you are in the setup page, go to the Wireless tab.
Take note of the wireless network name (SSID).
Then go to the Wireless Security tab. Take note of the wireless security settings and the network key (if wireless security is enabled).
On your laptop, in the lower right corner of your screen you will see an icon that looks like this moz-screenshot-1.jpgc147bd5.png.
Click the icon and you will see a list of available networks.
Select the SSID of your router then click connect.
If the wireless security is enabled, it will ask for the security key. Type the wireless network key, then click ok.
It will then connect wirelessly.
Dec 26, 2009 | Linksys Wireless-G WRT54GS Router...
My wireless picks up my network but wont connect. It doesnt even ask for the pass key, which it does for other neighbour networks. I have just wiped my computer.
Nov 28, 2009 | ASUS Computers & Internet
I want to setup a wireless connection
To set up wireless connection, first you will need to access the router set up. yhen change the wireless settings on the computer.
Secure the wireless network and then try to connect to the wireless network ?
Click Here for step by step info
Nov 22, 2009 | NetGear WGR614 Router
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Linksys Wireless-G WRT54G Router Logo
223 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
