Question about Microsoft Xbox 360 Console
Same problem My THIRD XBOX 360 is not working- Says play DVD instead of play game disc. Calling xbox to find out how to fix.
  • 3 Answers
If you have a flashed Xbox 360 it could be that the new game has a protection called Wave3.
That protection makes the games to run as a DVD if the speed of the dvd is not 12X.
Because when you got a flashed DVD, your dvd doesn´t play games and dvds at 12X speed.
That makes that wave3 is feeling a higher or lower speed than it should be and blocking it and says Play DVD. Exactly the problem you got.
Posted on Jul 27, 2009
My xbox 360 reads my xbox games as dvds. i can play dvds in it, but every time i put in a game the dvd play options pop up instead of game settings. I was wondering if there was a simple setting solution...
This is an uncommon problem with Xbox 360's, but I have heard of it before. I know of a few possible fixes:
  1. Eject the game you're trying to play so your drive is empty.
  2. Turn on your console.
  3. Insert the disc and see what happens.
Xbox 360's do not have the greatest DVD drives on the planet, no doubt. Another thing you could do is to connect your Xbox 360 to the internet and be sure you have the latest firmware update. This might remedy the problem. As soon as your 360 is connected, it will automatically detect if an update is needed and it will tell you it wants to download it without you having to do anything.
If neither of these work, chances are you'll need to contact Microsoft at 1-800-4MY-XBOX for technical support. If you're lucky, you're still under warranty.
Mar 12, 2011 | Microsoft Xbox 360 Console
When we put in a game for our 360 system it says it's playing a dvd we can't get the game to work. how do i fix it so it says play game amd not play dvd? (it only does this with 1 game. the rest work fine
Ok if your for certain thats the original dvd drive and the other games work then its too many scratches on the disc or your laser lens needs wiped off with qtip and rubbing alcohol.
If you get an xbox thats say play dvd all the time on every game and it says to play this disc stick in a xbox 360 console then its the wrong dvd drive for that motherboard and you wont get the key (on a chip in the motherboard on the cd drive) unless you have the original dvd drive taken out of your xbox. Then you can just switch that little motherboard on the bottom of the dvd drives and it will read games. This is for those who will look at this with a xbox off ebay that they cant figure out how to fix. Its just an expensive dvd player.
Dec 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
Xbox 360 arcade pal game read error
You will get this error when your laser is in need of replacing. The other message you will get is open tray. If your system will play regular movie dvd's but not games then replace the laser. You can find them pretty cheap on ebay.
Sep 11, 2009 | Video Game Consoles & Games
Xbox says play DvD when there is a game in the Disc drive....
Hi. You need flash the firmware from the old drive to the new drive.
Jun 11, 2009 | Microsoft Xbox 360 Console
Xbox 360
Some of the Xbox 360s have been known to have issues with their DVD-ROM Drives, On Older Xbox 360s The actual Drive has been known to cause slight scratching and scuffing to your Games and Movies.
If your Xbox 360 is having problems reading games, their is potentially a problem with the DVD Drives Laser, i had this issue last year with mine, Out of the blue the DVD Drive stopped working and wouldnt read Certain discs. The i would suggest Calling Up the Xbox Customer support Center for your Country (numbers Available on www.xbox.com/support) and explain your problem to the person on the end of the line.
The only solution is usually to return your Xbox to microsoft Free of charge, which will be either repaired/replaced and sent back to you.
Also, once the solution is solved, it is important to NOT leave Games/DVD's In the Xbox's drive when not in use, Especially when moving the Xbox around as this can knock the laser and cause a fault ! their is only ever a DVD in my xbox drive when it is in use, i take mine out all the time to help prevent these sorts of problems.
Hope This helps !?
Oct 27, 2008 | Microsoft Xbox 360 Console
Xbox 360 says to play disc put it in an xbox 360 console
The box isn't loading the decoder softwarer for the Disc. The Xbox discs are encoded HD DVD-ROM discs, and the box needs to recognize them so it can load the decoder software. It probably says "play dvd" on the xbox dashboard right?
Apr 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
158 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
