Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch washer code E-02
Where can I find info on a code E-02 on my Bosch washer Model WFMC2201UC? What does it mean and can I repair it myself?
caroldon
  • 17130 Answers
SOURCE: i need a service manual
You can get support from the main home site of Bosch but they do not share service manuals to customers. So log on and postt your querry to :
www.bosch-home.com/us/WFMC2201UC.htm
There is a link for you to check out for the manual and ZI hope it will be useful; Just try this link:
www.retrevo.com/support/?Bosch-WFMC2201UC-Washers-manual/id/925ci467/t/?2
Posted on Sep 17, 2010
michiganfan9
  • 179 Answers
SOURCE: washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Posted on Dec 26, 2008
  • 35 Answers
SOURCE: Bosch washer WFMC2201UC/15 has E13 error and will not fill
Hi  hartselectri,
Check the drain hoses and pump That code is for a longer than normal drain if it did not drain it would not let you open the door, You need to clean the filter. Remove the circular panel on the front right put a little screw driver in the hole and twist the access panel will pop off. Then you will need to twist the handle of the filter and pull it out you will find what is stopping the unit from draining in there very common. Also have a lot of towels handy all the water in the unit will come out when you pull the filter.
Regards
R.K.
Posted on Oct 21, 2009
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
worked perfectly! THANKS!!!! from a dad of 4 on a tight budget
Posted on Jan 24, 2011
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What does fault code e04 mean
    There are many brands of washers and the error codes are different.
    What kind of washer do you have. Brand name and model number.
    Open door and look around the frame for the model number.
    Here is a link to e04 on a Bosch washer.
    Repairing 04 Error on Bosch Washer
    Sep 10, 2014 | Washing Machines
    My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
    If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
    Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
    E13
    The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
    Anyway, here`s the most likely way to remedy a E13 code.
    Here the tips... support/t7599677-error_code_13
    Apr 25, 2011 | Bosch Nexxt 300 Series WFMC2201UC
    Error code 02 on a newly installed Bosch Nexxt Washing machine
    This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
    Jul 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
    My brand new Bosch is not draining and is showing E:13 error code
    Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
    Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
    Bosch 300 series washer// led code E04
    Remove the access panel at the front botton right corner. There is a manual release button you can pull.
    Oct 27, 2008 | Bosch Nexxt 300 Series WFMC2201UC
    Bosch washer too long cycle times
    Looks like the heater has failed.Contact Bosch direct to repair as it has a 2 year guarantee
    Mar 15, 2008 | Bosch WFL 2463 Front Load Washer
    Bosch Axxis WFL 2060 Front Load Washer Logo
    158 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
