Question about Kenmore Refrigerators
Cleaning stainsteel on Kenmore Elite
I have 2 yr. old Kemore Elite refrigerator. Every time I attend clean/ shine the front doors and drawers the get lines of shiny and dull.- looks terrible! Any suggestions?
    Top Expert:
  • Kenmore Master
  • 52,791 Answers
You may have to use special cleaner intended for stainless steel.
Posted on Jul 15, 2017
SOURCE:
rylee_smith
  • 8619 Answers
SOURCE: whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 06, 2009
  • 220 Answers
SOURCE: My Kenmore Warm and Ready drawer self cleaning
Hit cancel or kill the power at the electrical/breaker box.
Posted on Sep 03, 2009
SOURCE: Suggestions for cleaning the genn air stove top JDR8895aas
I have no solution but I have a Jenn-air stove, white with dual fuel and the oven door is badly stained on the top, probably from the vapors when self-cleaning. I have tried many things and they won't touch it. can someone help me out
Posted on Oct 24, 2009
Macmarkus
  • 2605 Answers
SOURCE: Do I remove the racks before self cleaning my
It is a matter of personal choice to whether you remove the rack`s or not, no harm will come to you from not removing them but...If they are chrome finished they will become very dull and look like bbq grills over time and in extreme cases, warp and consequently not fit well.
If they are finished with enamel to match the oven liner, don`t worry, they are designed to be left in place, even during self clean cycles.
As for how you can clean them. You can do this by removing them and with a suitable work space (a bath tub or laundry tub works great) with regular oven cleaner`s, (preferably environmentally friendly...check your local by-laws) or other household cleaners with the assistance of a scrub pad and elbow grease. Be sure and rinse them thoroughly when finished with the cleaner`s.
Hope that help`s. If so, please take a second to rate the solution provided by me here at fixya. Thank you.
Good luck.
macmarkus :)
Posted on Dec 05, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Posted on Sep 29, 2010
After new fridge delivered found 8 loose ball bearings in freezer compartment below drawers. Freezer draw seems to be working properly
David, very Odd, check all drawer slides if all function good and no visible missing parts missing (like one slide has bearings and one does not), a repair may have been made already and what you found is left over. Contact dealer to see what they have to say about it and ask them to make a note of it for warranty purposes.
Mar 26, 2016 | Kenmore Refrigerators
How do i get to the main drain and pump on a kenmore elite front load washer
You will need a few towels. There is a cartridge like filter located on the front lo2er left corner of all current front load washers for cl3aning purposes. Remove or open the access panel plate and begin unscrewing the cartridge. After about 3 full turns it will begin to leak water. If you have a elevation base with a drawer place towels inside there to soak up water that leaks out. Once drained unscrew and pull straight out to clean the lower filter. There is another place to clean out just inside the drum on the front just under and behind the door seal
Jan 03, 2015 | Kenmore 4.0 cu. ft. Steam Front-Load...
French refrigerator has green mold in refrigerator under metal p arts that I can't get to or clean
Children do not create mold or germ problems. Try to make a cleaning tool that does reach into the area, perhaps bending a long metal spatula or a barbecue brush.
Dec 14, 2013 | Computers & Internet
Our Kemore refrigerator seem to be running constantly. It is only 4 years old. Out of 5 hours it has been running 2 hours and 43 minutes, at different time intervals. Temperature in freezer and...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore Elite refrig./freezer (2 doors refrig on top, 1 pull out drawer freezer on bottom) is not working correctly. The front panel where the temps are set, light, etc. now has flashing lights that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 11, 2010 | Kenmore Refrigerators
Mould in water inlet assembly how to remove this assembly for cleaning. the fabric softner try never gets drained. Has a three valve inlet sysrem.
Pull the dispenser drawer out until it stops then push down the release tab and pull the drawer out completely. Separate the parts then immerse it in hot water with bleach and give it good a scrub with an old toothbrush.
The dispenser drawer cavity does not need to be removed for cleaning. Otherwise, you have to remove the top panel, console, toe panel, and the front panel. Removal of the front panel requires the removal of the door lock/switch assembly and the boot be separated completely from the front panel opening. Use hot water to loosen the mold then spray it with household cleaner with bleach. Let it sit for a couple minutes before starting to scrub the molds off.
Jul 03, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 106.53552201
refrigerator works for a day and then quits working
Feb 04, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
