Question about RoadPro AC/DC Power Inverter 80/100w
Inverter keeps shutting off on solar panel system
3000 W motomaster eliminator. Shows charged but when you turn on the inside power, outside on eliminator shuts off. Shows only red light on panel. Is it toast?
Why doesn't it charge?
Carolyn, These power boxes were not made to last, the batteries inside are probably bad now, if still under any warranty return for exchange or hopefully refund.
Feb 09, 2016 | Eliminator MotoMaster Mobile Power...
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Motomaster eliminator 2 in 1 spotlight/lantern power
I am looking for a charging cord...I moved and haven't seen it in a while. Is there somewhere i could buy one.
Dec 02, 2013 | Eliminator MotoMaster Mobile Power...
Have an eliminator intelligent battery charger model CT-1200A 11-1513-8. Can this be used to keep a car battery charged for a period of say 3 months while car is not being used. I have this same question...
· Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
Nov 27, 2010 | Eliminator MotoMaster Mobile Power...
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Oct 24, 2010 | Eliminator MotoMaster Mobile Power...
Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
May 20, 2010 | Eliminator MotoMaster Mobile Power...
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Nov 25, 2009 | Xantrex Technology Trace Series Inverter /...
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
RoadPro AC/DC Power Inverter 80/100w Logo
82 people viewed this question
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
