Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Every fifth line or so of text has a missing streak in the middle. ie across the page Do I need to clean something??
  • Epson Master
  • 511 Answers
Check nozzle. Is there some lines missing? Do head cleaning procedure from peinter maintenance. Wait for 15 minutes. Check nozzle again. If there is just little missing lines, you can print with fine/photo quality fot better result.
Posted on Jul 27, 2009
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Canon i3235
Are the lines across the page, in the direction of text, or from top to bottom. If from top to bottom, watch the scanner bar with the cover up, see if anything looks odd. If the paper moves in this machine, like from an auto feeder, it could pick up a streak from something in the path.
Checking, this unit is a laser printer. When replacing toner, there usually is a little tab thingy that is supposed to be moved back and forth over a little wire. The wire must be kept clean, too. Also, there may be a white bar with a glass cover that is to be cleaned very carefully every time toner is changed. Find this piece of glass, a speck of dust is probably your culprit.
Nov 26, 2013 | Office Equipment & Supplies
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Every fifth line has a white streak through the
I would try using something like rubber renew on the pickup rollers and make sure that the paper is being fed correctly. If this is happening then start looking at the ink.
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Some printers will let you re-run a cleaning utility from their system menu or the computer printer properties. Keep in mind too that some printers will not print correctly, even with full ink, if the exact type of ink it expects you to have is not installed. If all else fails change out the ink, but double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily is the right type and using the wrong ink can cause unexpected results.
Nov 08, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Black streaks across the page
hello,first of all,make a copy true the adf,and the next on the platen glass,if both copys are good,then the problem is inside the machine,i.e.drum unit or fuser roller damage.
if the strikes only occurs,by using the adf,then cleaning the scanner platen glass,it is the small glass unit!!! on the left side,from the big platen glass..
good luck Sjeuf
Apr 11, 2008 | Panasonic Workio DP-2330 Printer
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
PC940 dark lines across the middle of the page
Either the Fuser/Heating unit is bad, or the optics are dirty.
What you can try to do to narrow it down, is to make a copy but.. STOP the machine in mid process by turning the power off. This will create a paper jam in the machine. If timed properly, your copy should be 1/2 way through the machine with some image on it. (Make sure that you are trying to copy something on the glass). The copy is not FUSED, so the toner will wipe off so be careful not to rub the page against your clothes/sleeve. IF the black line is on the page at this point, the problem is not in the fuser but probably in the fiber optics. If the problem is in the optics and will need to be cleaned. If the black line is NOT on the page at this point, then the fuser unit is bad and needs to be replaced.
Let me know how the copy comes out when you stop the machine in midway and I can see if i can give you any more suggestions.
Good luck.
Mac
Feb 12, 2008 | Canon PC-940 Black and White Copier
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
619 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
