Question about Whirlpool SF367 Gas Kitchen Range
Whirlpool oven RF365PXMQ0 oven elements remain on when off
The oven elements remain on after the bake function has completed.
    Guru:
  • 310 Answers
Maybe wiring short or control board malfunction. You may need to ohm it out.
Does it clear after you cycle the power? - or just stays heating away?
- www.fixyourboard.com
Posted on Jul 27, 2009
Larger heating element not working on outer
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Apr 21, 2014 | Whirlpool Ovens
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Dec 17, 2008 | Whirlpool RBS305PDS Electric Single Oven
    Instruction manual
    HI SIR
    When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
    Multifunction Oven Function Selections
    2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
    3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
    4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
    5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
    6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
    7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
    8. Fan-assisted Baking or Patisserie Setting
     - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
    top
    Advanced Oven Features
    Cavity Cooling
    The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
    Triple Reflective Door Glazing
    Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
    Wipe Clean Enamel (Extra Optional)
    Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
    Drop Down Grill Element (Extra Optional)
    The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
    top
    The Electronic Timer
    Normal Baking
    Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
    To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
    Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
    top
    Fan Forced Baking
    Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
    Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
    Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
    Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
    Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
    top
    Grilling
    Function 5 & 6: During grilling the door may remain closed or completely open.
    This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
    Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
    Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
    Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
    Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
    As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
    Sep 11, 2008 | Ovens
    Oven stopped 5 to 10 minutes after pressing START
    sounds like a wiring problem check your power source
    Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
    Whirlpool oven issue
    Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
    Whirlpool SF367 Gas Kitchen Range Logo
    103 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
