Question about Sport & Outdoor - Others
I have a 1987 yamaha warrior
It leaked gas at first then we got a new petcock for it, it stopped leaking, then a couple of days later it starts leaking again, so I rebuilt the carb, it stopped leaking, but now it is leaking again.
what is wrong? what do I do?
  • 32 Answers
The only thing i can think of is that you might want to take the carb off and really clean it good where it bolts down and around the entire area if thats where its leaking from. Hope i was of some help to you.
Posted on Aug 03, 2009
My warrior starts but it seems like it's not getting any gas when you let go of throttle
You might want to try unplugging the parking brake sensor it helped me. it is located on the clutch lever it is the top wire that is closest to you while you are sitting on the bike. follow it down to underneath the hood disconnect it see how it runs.
May 03, 2016 | GAS Motorcycles
Stopped and got gas then it started and died, acts like it's not getting any fire
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Re Bike runs for seconds then dies then starts fine Road Star Forum Yamaha...
02 Warrior Starts Then Dies After Few Seconds With Spitting and Sputtering
Yamaha XV1700PCRC Service Manual
OEM parts for Yamaha
Yamaha WARRIOR XV17PCV Owner Manual
Apr 25, 2014 | 2002 Yamaha Road Star Warrior
Any thoughts on 2006 Virago 250 with gas leaking out of right exhaust pipe?
Hi, Andrew and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Gas coming out of exhaust help
Fule Dumping out of exhaust will not start
Yamaha VIRAGO XV250S Owner Manual
Yamaha XV250G Supplementary Service Manual
May 05, 2013 | 2006 Yamaha Virago 250
2002 Yamaha Roadstar Warrior will not start
Hi, Jjs186 and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike will not start
What to do When Your Motorcycle Won Start
Yamaha XV1700PCR Road Star Warrior Owner Manual
Jun 18, 2011 | 2002 Yamaha Road Star Warrior
1987 Toyota Camry, auto, 4 cyl. I thought I was low on gas (since had fuel light on)...car would not start. Walked home (20 mins) came back and added fuel (1 gal), started and drove to gas station - filled...
theres a couple of things to check for this first generation series,, check the Air flow meter connector FP terminals, and intake tube, make sure its tight and doesnt have a leak.
May 31, 2011 | 1987 Toyota Camry
Have gas getting into crankcase, what would cause this? petcock?
Hi ,,,a petcock that is not closing can cause this, also if there is gunk in the carbs in the float needles,,will also cause this.
Mar 23, 2011 | 1987 Yamaha YX 600 Radian
I have completely rebuilt the petcock but I still have a serious gas leak. Can you help?
Did you replace the vacuum diaphragm on the back of the petcock? That is usually the cause of fuelcock leaks on Yamaha's. Yamaha only offers the diaphragm in the complete petcock assembly. The only way to get a diaphragm separately is in the K&L petcock rebuild kit. Unless your leak is dirty carb/bad needle related and not petcock related.
Aug 24, 2010 | 1979 Yamaha XS 650 F
Fuel leaking from petcock bolts
i know of a mechanic that uses PTFE TEFLON plumbing tape on harley petcocks. my bolts i got with my xvs 650 petcock dont look any special.
a bit of thread lock may do it fo you
Apr 12, 2009 | 1987 Yamaha FZR 1000
Yamaha yzf600 wont start
Hi, John and the usual suspects are:
YZF600R Forums View topic Carbs overflowing
Carbs leaking Here is how to fix it
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Yamaha YZF600RP Owner Manual
Mar 08, 2009 | 2003 Yamaha YZF 600 R thunder cat
QUAD QUESTION! 1998 yamaha warrior 350 bogging down
sounds like fuel starvation
do you have a petcock plugging or a dirty carb?
pull the fuel line and check flow
Nov 17, 2008 | 2003 Yamaha YZ 250 F
Sport & Outdoor - Others Logo
110 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
