Computers & Internet Logo
Andrew Austin Posted on Jul 14, 2017
Vlookup for duplicate cell values to display both names in separate cells
1. Column 1 = data 2. Column 2 = names 3. Cell 3 = max value from column 1 4. Cell 4 = vlookup for the highest value in column 1 and display the name in column 2 against that value. 5. Cell 5 = vlookup for the highest value in column 1 and display the name in column 2 against that value. The name in cell 5 should display the second value not the first value again. Can I send my excel work book to some one that can help me.
  • Andrew Austin
    Andrew Austin Jul 14, 2017
    I would like to send a copy of my excel sheet to someone that can help me, as my problem is still not resolved.
  • Andrew Austin
    any e-mail that I can send it to
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Sep 24, 2007
SOURCE: ms excel
Vlookup: =VLOOKUP(A1,A1:C10,3,FALSE) 1. Lookup_value - A1 the value you want to search. 2. Table_Array - A1:C10 You will only search the lookup_value in the left column which is A1:A10 in this example. 3. Col_Index_Number - If you find a matching value give me column 3. Since A1=A1 it will give me C1. In this example 1 is A, 2 is B and 3 is C. 4. Range_lookup - I always choose false which is exact match. True will give you approximate match and its not always correct. Vlookup is used when you have a list of values and you want additional values that exist in other fields. You will get those values only for the fields that you search for. In your example you can get the address by running vlookup at the names, it is also good way to search duplicates. Q2 is very simple, on field D1 just type: =A1 & " " & B1 & " " & C1 Just drag it or double click on the drag square Let me know if you have any other questions Daniel
Anonymous
  • 28 Answers
  • Posted on Dec 30, 2007
SOURCE: Using if and then to add values to a cell
Try using the SUMIF function for one condition or multiple conditions. Use the SUMIF worksheet function to create a total value for one range based on a value in another range. For example, for every cell in the rage B5:B25 that contains the value "Northwind", the following formula calculates the total for the corresponding cells in the range F5:F25. Formula:
=sumif(B5:B25,"Northwind",F5:F25)
Here are SUMIF functions for multiple conditions.
=sum(if((B5:B25="Northwind")*(C5:C25="Western"),F5:F25))
=sum(if((B5:B25="Northwind")+(C5:C25="Western"),F5:F25))
=sum(if(B5:B25="Northwind",IF(C5:C25="Western"),1,0)))
Also check your help for SUMIF functions.
If this helps you, Please rate me. Thanks, Patty
CNewton2
CNewton2
  • 27 Answers
  • Posted on Mar 10, 2008
SOURCE: excell vlookup formula
Suggest you do some debugging in steps:
1. Open the 'bills up to 022908.xls'
2. Use an empty cell to "=CONCATENATE(D3,L3)". That way you can see what values are being generated.
3. Copy the values of that cell and see if you can find them in Col G of 'bills up to 022908.xls'.
Once its broken down into pieces you can usually see "the error of your ways."
Hope this helps.
Anonymous
  • Posted on Oct 02, 2008
SOURCE: Using Vlookup to copy data from another worksheet
=if(isblank(vlookup(Sheet1!A1,Sheet2!$A$1:$B$4,2,0)),"",vlookup(Sheet1!A1,Sheet2!$A$1:$B$4,2,0))
Anonymous
  • Posted on Dec 18, 2008
SOURCE: Some cells return #N/A
the issue is that you may be trying to find the the data which is not there in the table PROV hence you need to have a look at the data in the table PROV
first see if the data you are trying to find is there in the table or not (use crtl+f) to see if the data is there in the table.
How to calculate next sequential number using multiple columns
Try using a formula like this in Col AI:
=IF(AG9<>1,0,MAX(AI$1:AI8)+1)
A couple of notes:
1. You'll need to adjust the references for this formula in the first row of each new column you use.
2. If you don't want Zeros for the cells that don't increment, the you can use "" instead to get blanks.
I ENTER A VALUE IN COLUMN B AND WANT TO FIND THE SAME VALUE IN COLUMN A THEN WRITE THE SAME VALUE IN COLUMN C IN THE SAME ROW IT WAS LOCATED IN COLUMN A
You write A VLOOKUP formula in the cell in column C which looks up the value referenced in a cell in coulmn B to a range in column A, the values in column a must be in ascending order.
If you need more help post a comment.
4helpful
5answers
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
2answers
How to use vlookup
you can a tutorial here.
please rate.
How do I say look at cell on left rather than the cell number
vlookup can only locate values within the lookup range and to the right of the lookup column. to address your concern, i'd advise you to create a dummy column within the lookup range (and hide it) and link it to the lookup column. this way, we won't need a (-) column index number.
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
Excell vlookup formula
Hope this helps.
Lookup,s
If you can move your name column (C) to the first column, you could leverage the VLOOKUP formula pretty easily.
To do this, do the following:
1) Move the C Column to be the A Column, shifting all other columns to the right.
2) (optional) Insert a new row at the top of the sheet (to hold the formula & seach value)
3) Use A1 as your search field.
4) In A2, enter the following formula:
=VLOOKUP($A$1,$A$2:$C$6,3,)
Describing above parameters, in the formula:
$A$1 -> the search field (name your looking for).
$A$2:$C$6 -> The table/grid you wish to search and return values from. The left most column (A) must contain the values to be searched.
3 -> is the column number (A=1,B=2,C=3, etc) within the table/grid to return.
If you cannot make the name column your first (A) column, there are more complex ways to do this. For instance, create a new sheet which redisplays the info in the structure easier for this method, and perform the VLOOKUP on that data. Other options might exist in creating a complex formula that would get you what you want.
Also, if you can sort column A (names) it would find results faster, if your data set is large.
Ms excel
3answers
Function
VLOOKUP is to Searches for a value in the leftmost column of a table, and then returns a value in the same row from a column you specify in the table. Use VLOOKUP instead of HLOOKUP when your comparison values are located in a column to the left of the data you want to find. The V in VLOOKUP stands for "Vertical." Syntax VLOOKUP(lookup_value,table_array,col_index_num,range_lookup) Lookup_value is the value to be found in the first column of the array. Lookup_value can be a value, a reference, or a text string. Table_array is the table of information in which data is looked up. Use a reference to a range or a range name, such as Database or List. If range_lookup is TRUE, the values in the first column of table_array must be placed in ascending order: ..., -2, -1, 0, 1, 2, ..., A-Z, FALSE, TRUE; otherwise VLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted. You can put the values in ascending order by choosing the Sort command from the Data menu and selecting Ascending. The values in the first column of table_array can be text, numbers, or logical values. Uppercase and lowercase text are equivalent. Col_index_num is the column number in table_array from which the matching value must be returned. A col_index_num of 1 returns the value in the first column in table_array; a col_index_num of 2 returns the value in the second column in table_array, and so on. If col_index_num is less than 1, VLOOKUP returns the #VALUE! error value; if col_index_num is greater than the number of columns in table_array, VLOOKUP returns the #REF! error value. Range_lookup is a logical value that specifies whether you want VLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, VLOOKUP will find an exact match. If one is not found, the error value #N/A is returned. Remarks If VLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than or equal to lookup_value. If lookup_value is smaller than the smallest value in the first column of table_array, VLOOKUP returns the #N/A error value. If VLOOKUP can't find lookup_value, and range_lookup is FALSE, VLOOKUP returns the #N/A value.
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
