Question about Symbol LS 4071 Handheld
Symbol Scanner LS4071-I1us
I have a LS4071-I1us scanner with the synapse/adapter/usb connection.
After scanning an item/ISBN#, it makes a beep like it has scanned, but nothing shows up on my pc screen.
Does anyone know of a solution to this problem?
  • kybigfoot1 Jul 27, 2009
    How do you fix the transltor and data comparison problem?
  • 724 Answers
Transltor and data comparison failed?
Posted on Jul 27, 2009
  • tommya300
    tommya300 Jul 27, 2009
    The scanner is just an eyeball that needs to have a database to compare what it sees! Certain amount of bars thickneses and spaces equil what ? You need the talking to the scanner type software...
    http://www.barcodehq.com/software.html
Symbol LS4071-I116 or Symbol LS4071-I1US paired with the RL474 cradle base.
1st problem: scan gun is not scanning anything? You have to pair the scan gun with the cradle or base in order for it to send the signal to the base. The pairing bar code is at the base where the head of the gun rests when charging.
2nd problem: scan gun is already paired with the base and it beeps when you scan something but nothing comes up on the screen? To begin with, the problem is not the program where you trying to put the information in. I use AS400, Microsoft Word, Note Pad, etc. Once the scan gun is working properly it will send the information to any of the previous mentioned programs. Having said that, the gun already being paired with base and nothing comes up on the screen? There might be a connection problem. I will explain this as we go.
3rd problem: your gun is connected to your PC via USB? If that is the case you should not have a problem with your PC recognizing the LS4071 scan gun because USB connections start up automatically and most of them will prompt if you need to install a soft ware for it to work. If the PC is not recognizing the USB connection, the best to do is restart the PC.
4th problem: your gun is connected to your PC via PS2? If you do not know what PS2 connection is research because it is very important that you understand what I mean by that. So, your gun is connected to the PC via PS2 and you are using a Symbol Synapse Smart Cable (Model: STIXX-XXXX). It is kind of a per say Y cable. There are 3 connections going on here. First, the cable coming out of your gun (not the power cord) has to be connected to the Synapse cable. Second, if the LS4071 is connected to the PC via PS2 using a synapse cable you MUST read well you MUST have a keyboard that has the PS2 connection, or else the computer would not recognize the gun. It would not recognize it because the Symbol cradle or base does not start up automatically because it is not necessary for the PC to work. And the third connection goes to your PC. Now if you have the keyboard connected to the Synapse cable, once you start the PC it will automatically recognize the keyboard connected to the synapse cable because the keyboard is a main part for the PC. Therefore, once the keyboard is recognized by the PC the scan gun will also be recognized because they are sharing the same connection; that is the main purpose of the Symbol Synapse SMART cable. Furthermore, the Synapse cable connector is connected to the PC, the keyboard is connected to the Synapse cable, and the gun is also connected to the Synapse cable. Everything looks fine it should be working now. If it is still not working, go ahead and restart your pc.
If you need more information about these guns go to the Motorola website, that’s where the manual and reference guide is at.
Thanks.
Posted on Apr 08, 2010
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
Oct 28, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
I am trying to find the software installation file for a 123scan LS4071-I1US
OK try this trick . take any product lets say a tissue box and scan the barcode and see if it show the same problem?
if it is the same try to clean the scanner until we figure out something else.
if it reads it full the n the printed barcode are the damaged ones.
May 11, 2010 | Symbol LS 4071 Handheld
Symbol barcode scanner LS4071 + base RL475
Hi, you will need the 25-17821-20 and STI80-0200R cables to connect to PS/2. You must have a PS/2 keyboard for this connection.
If you would prefer to connect to a USB port you should get the 25-17821-20 cable with the STI85-0200R.
The RL-475 was for the IBM, but it also supported Synapse which is the STI cable.
Nov 18, 2009 | Computers & Internet
How to setup symbol m2000 sanner USB
You would need to use the Synapse Smart Cable Adapter to use this scanner with USB interface. The Product Number for the adpater is STI85-0200R.
This one can be connected between the scanner and desktop PC or other host. It supports the standard USB HID drivers
Sep 25, 2009 | Symbol Cyclone M2004 Handheld Barcode...
Symbol HotShot LS2106 sounds like it's scanning, however, no data/information is displayed once scanned. Connecting to Windows XP with a USB converted to PS2 cable. Are there reset bar codes available that...
The LS2106 did not support laptop mode so the PS/2 wedge needs to have a PS/2 keyboard attached to the cable. If that does not work I would suggest trying to find a 25-31617-01 Synapse adapter cable and STI85-0200 USB Synapse cable. This would allow you to connect the scanner right to the USB port and it should work without any extra programming. I believe the cost of the two cables (if you have to purchase them new) is almost as much as a new LS1203 scanner with USB cable. At least with the new scanner you would get a three year warranty.
Jul 03, 2009 | Symbol Hotshot LS2106 Handheld
LS 1004 Symbol Barcode Scanner
The host type are the Interafces which are supported by the scanner directly (no adapter needed). And the Synapse adapter can even an old scanner connect to new interfaces like USB.
As you state you have the adapter for keyboard wedge. You would just need to download the Reference Guide for the "Synapse Smart Cable" at support.symbol.com a configure it acccording to your connection parameters.
Mar 13, 2008 | Symbol Spark LS 1004
Ls 9100
The first thing you need to do is set the LS9100 to know it's connected to a synapse cable. Scan the "set all defaults" barcode and then the "set synpase host" barcode. Once you have done this you can program the unit for the specific synpase cable your purchase, such as USB, PS/2, etc.
Oct 06, 2007 | Symbol PDT6842-NIS632EU Portable Data...
Symbol LS 4071 Handheld Logo
2,348 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
