Question about Garden
Grinding Noise when moving
I was mowing my backyard this afternoon, and all of a sudden there was a grinding noise as I was moving. The yard is more or less flat, and I know I didn't hit anything (sticks, etc). Obviously I stopped, disengaged the blades, and shut down the mower. As I shut it off, I lifted the hood and listened. The engine seemed to be running okay, but there was a little bit of white (I think) smoke coming off of it. It smelled hot. I let it sit for a couple of minutes and checked the oil. It was right in the middle of the good zone. I restarted it (started fine) engine seemed to be running fine, but sounded just a little off. I put into drive, and with throttle low, moved forward. It sounded like a car that was dragging a muffler, and had a lot more vibration than I think is healthy. As I took it back to the shed, I played with speed and throttle a bit. the faster the speed, the worse the grinding/dragging noise. It seemed to be coming from directly below me. the throttle speed didn't seem to effect anything, as long as my ground speed stayed steady. Also the faster I went, the worse the vibration. obviously I generally went slow as to try to minimize any damage, but thought it was worth it to try to get some more info while it had to move it anyway....
    Scholar:
  • 173 Answers
This could well be the diff trans assembly.
If the machine is relatively old, then it's probably due.
I'm afraid you're going to have to get on your hands and knees, in order to inspect the under side. Where the source of the noise is coming from.
Check for unusual wear, loose or missing fixings and oil stain's.
In general, anything that looks out of place.
The oil btw, should be changed regularly, as there is no filter that helps the 'lasting' life of the it.
Also, some of these could be signs of a fault of the engine, which could be quite serious.
But I think it's more likely, some loose or missing bolts. Check that everything that shouldn't move (Like the transmission), doesn't.
And while you're there, inspect the belts.
Hope that helps:)
Posted on Jul 27, 2009
4 Suggested Answers
  • 4 Answers
SOURCE: deck drive belt comes off when disengaging mower
Need to adjust the tension on the belt.
Posted on May 18, 2009
  • 13 Answers
SOURCE: my mower will not disengaged when i engaged my
Is it a manual are electric clutch
Posted on Sep 29, 2009
  • 8 Answers
SOURCE: WHEN I FINISH MOWING YARD I DISENGAGE MOWER BLADES
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
Posted on May 18, 2010
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
My timing belt was changed 75000 miles ago, its now making a grinding noise, is it time to change it again? Can a backyard mechanic due this project? Is there a free guide for this project?
There is a haynes,or mitchel manual you can purchase for this,and do it yourself,providing you have the tools,and you need to check all the components envolved with the timing belt to ensure there is no other reason for the grinding noise.
Mar 16, 2010 | 1996 Lexus ES 300
Car pulls right, terrible grinding noise from front right.
TAKE IT BACK WHERE THEY DONE THE LAST LOT OF WORK and tell them to do the complete job again as it sounds like a con job to me as a wheel aligment should last for a year a least and the grinding is in the braking system and something must still be bent ,
Its still under warranty dont pay any more..
Oct 26, 2009 | 1993 Buick Regal
Grinding noise
The most common problem is that the pulley breaks, you might be able to see it through the glass. looks where the belt goes, and see if the pulley is broken.
also, some people forget to unlock the locking mechanism when the unit gets moved, the locking switch is on the side.
Apr 09, 2009 | Epson Office Equipment & Supplies
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Soft clicking-grinding noise
i think that you have the full-time auto focus on.
go into the menu and turn it of and all should be fine.
seekreep from Edinburgh - Scotland.
Jun 10, 2007 | Olympus C-7000 Zoom Digital Camera
Garden Logo
217 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
