Question about Pioneer CDJ-700S Turntable
Cdj - 700s
The player cannot open the lcd display say err 9102 what can i do troubleshoot this problem?
  • 515 Answers
Re: cdj - 700s
Error 9102 is a disk read error, and you either have a damaged reader or there is something seriously wrong with the tray unit causing the error. Troubleshooting is not that simple for this unit, you will need a multimeter, and possibly an oscilloscope to trace the error. More than likely, you will need to have the tray replaced if the error persists.
Posted on Nov 23, 2007
0 characters
3 Points
Hi - I have a CDJ 700S which skips intermitantl...
Hi Tony, you should also, explain how old is your pioneer cdj 700s. I hope you have done all what you could.
May be your player have lived his life and its leaser needs to be replaced.
May 19, 2010 | Pioneer CDJ-700S Turntable
PIONEER CDJ 400 E-9101
E-9101 error is mechanical time out. You need to clean compartment to your player, dirt or dust may be there into insertion compartment to the CDJ
May 13, 2010 | Pioneer CDJ-700S Turntable
Pionner cdj 400 with e-9101
The IC Protector is mest up in the unit is a very small piece that cost around 1 or 2 dollars it costed me 130 to take it in to a technician to fix it so do some research on the ic p its type N IC p!
Jan 29, 2010 | Pioneer CDJ-700S Turntable
CD wont spin so player cant read it. Looks like all other features are working.
Not sure, but it may be related to the optical assembly... it´s always about the optical assembly lol... Does it display any error message?
It can also be something wrong (bent, broken, too much dust) with the blinds-like mechanism where the CD lays down (closed when lid is opened, opened when the lid is closed). So if it can´t "see" the disc, either by a problem on both mechanisms, the spin motor doesn´t starts.
Liberty electronics on ebay have now the ultra-rare DWY1067 optical assembly. Have a check at the sticker on the back of your 700s player, above the barcode. If it was manufactured until 2000-2001 you´ll probably need a DWY1067. After that, you´ll need a DWY1069.
Hope it was helpful
Fernando Seiji Imay
Sep 04, 2009 | Pioneer CDJ-700S Turntable
My pioneer cdj-700s no run
Probably your optical unit is worn. If you 700s are the newer ones, it'll be easy. Unscrew the 4 black screw under the unit to release the cover. Is the optical unit is exposed, check the label over it. If it says DWY1069, you'll only have to replace it, readily avaliable on ebay. It can be found very cheap ($15-$25).
If it says DWY1067, you have a big problem like me. 1067 is out of production. Check my other posts on how i'm trying to solve it.
Best Regards Fernando Seiji Imay
May 25, 2009 | Pioneer CDJ-700S Turntable
Pionner CDJ700S Lens, DWY1069 replace the DWY1067?
Hi Marcelo. I´m from Brazil, same CDJ-700s, same problem as yours. From what I´ve researched until now, DWY 1067 an DWY1069 ARE NOT FULLY INTERCHANGABLE on CDJ-700s and maybe 500s. I think some newer 700s already came out with 1069 from factory, so this is why all this misunterstanding. On older 700s that came out with 1067, some SMD components must be changed in the mainboard in order to 1069 work properly. Mine came ou with 1067, I´ve replaced it with a 1069, didn´t worked well (sound skipped, or didn´t play at all).
In 2001 Pioneer released a replacement kit for this situation. The kit is named GXX1200, and includes the optical unit (DWY1069) which is included in the whole mechanical unit (DXXsomething, depends on model), and SMD resistors and capacitors for replacement. Dirty job, I know...
Since I already bought the replacement 1069´s, I´ll buy the SMD components too. I´ll let you know if will this work. Not an easy task, but I´ll try.
Here you can check the whole kit:
And here the documentation for the replacement:
Fernando Seiji Imay
Apr 16, 2009 | Pioneer CDJ-700S Turntable
How to detach plastic tray to replace a CDJ-700s DWY 1069 Lens?
There are actually 4 screws. If you can only see 3 then this means the pickup (DWY1069) is already exposed and you do not need to remove the tray.
From here, detach the cable to the pickup (lift the small dark brown cable lock) then loosen the screw on the holding the slide next to the stepper motor and remove the screw at the other end of the same slide. Then the pickup should easily come out.
Feb 14, 2009 | Pioneer CDJ-700S Turntable
Hi Je remy
I have a 700s too, it´s showing problems similar to yours. Mine is even worst, it almost doesn´t play no more (shows "NO DISC"). Sometimes, when i turn it off and on, or open the cover, it reads... When pause is pressed, it holds the music for some seconds, then it "slides" thru the music... Sometimes it display an error message (something like E-8something).
I think all these errors are caused by a worn optic reader, but i´m not sure. I´ve already opened my unit and cleaned the lens, but no bail.
Here in Brazil a new optic reader can be found for R$150 (around U$90). I´ve just found out the same unit in UK for 150 pounds, so i´m suspicius that those units sold here aren´t really new... I´m planning to replace mine, but first i must be sure that the problem is really caused by the reader.
I don´t know if u have already opened yours, but it´s pretty simple to replace the unit, just some screws to loose (12, if i´m not mistaken - 4 ouside, 4 holding the lens protective cover, and 4 holding two inox sticks where the reader slides over). 700s´ units are Part No DWY1067, and you probably won´t find those anymore. You´ll only find the DWY1069, originally found in CDJ-100s (technically almost same, but probably some newer technology), but they´re totally interchangeable.
Hope could be of some use.
If u want, can contact me at
This is the unit seller here in Brazil:
Mar 28, 2008 | Pioneer CDJ-700S Turntable
CDJ 700s Turntables
Give me your zip code, and I'll try and look up a local service center in your area. Otherwise, if your in the NYC Metro area, you can drop it off here:
195 Morgan Ave
Brooklyn, NY 11237
You can also ship your unit in, by filling out the following Free Estimate form.
Nov 23, 2007 | Pioneer CDJ-700S Turntable
Open error
So your tray does not open? Could either be a faulty switch, or the tray might be damaged. If you are getting an error, then that means the switch is ok, because it is sending the eject signal to the unit. So you might have a faulty tray, or loading motor. Not an easy self-fix.
Nov 22, 2007 | Pioneer CDJ-700S Turntable
Pioneer CDJ-700S Turntable Logo
182 people viewed this question
Top Pioneer Turntables Experts
Dennis McCollum
Are you a Pioneer Turntable Expert? Answer questions, earn points and help others
