Question about Refrigerators
Thernoelectric Wine Cooler not cold
LWC18B AvantGarde Thernoelectric Wine Cooler can not reach the good temperature. Steel too hot. The fans are clean and running.
  • 27 Answers
Check internal and external fans are running if not replace them
Posted on Jul 29, 2009
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Tip
Haier Thermoelectric Wine Cooler
This wine cooler hasn't held temperature for months, even though during the winter my living room gets to 58 F at night. I've had it maybe a year.
I took the back off, and 2 of the 3 heat sinks felt cool, which means the thermoelectric pack was just conducting cold out of the cabinet in 2 of 3 cases. The third one felt slightly warm, as it should. I checked that the cool ones had 12 v to them, they did, so they should have been pumping heat out.
I put bowls of ice inside the unit, and when the temperatures got down to the set points, I heard relays click, so I figured the control unit was OK.
I removed one of the TEC modules that was cold on the outside, and taped up the hole with masking tape.
I unplugged the fan from the circuit board and unscrewed that fan assembly from the heat sink.
I then clipped the leads to the TEC unit, cut away the blobs of hot melt glue, and disassembled the cooling module. I took the TEC device and hooked it back up, making sure it had voltage to it. After awhile, both sides just felt slightly warm so I knew it was bad.
Got on line and ordered 4 (to have spares) TEC1-12703 coolers. I have thermal grease. When the parts come, I will re-assemble and should be good to go.
I don't know what blows the TEC devices, they should be very robust. Maybe Haier got a bad bunch of them, I read almost all bad reviews on these wine coolers.
on Apr 03, 2010 | Haier HVTB40DPABS Wine Cooler
Wine refrigerator keeps beeping every few seconds and temperature display is all over the place and keeps changing on the display different temps and from F to C
Unplug the unit for 20-30 minutes then reconnect. If it works correctly I would say you have a mother board issue.
Jun 21, 2015 | Refrigerators
My Magic Chef MCWC44DZ Wine Cooler does not get cold. i do not have any error messages any more due to me ordering the PTC relay and fixing the connections. I see the bottom fan working and i feel the...
You may have a Freon leak at the compressor. Running this unit at low pressure will only make it leak that much more. Have a technician check it and refill is there is a fill port available.
Feb 26, 2014 | Magic Chef MCWC44DZ Wine Cooler
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Apr 21, 2012 | Candy Refrigerators
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Can't change the cooler's temperature? the temperature reads LL and its very cold.
LL is an error code which means that it is too cold. Surprised that it didn't freeze something. Problem is likely the thermostat ($15 - RF-7350-55) or motor control board ($50 - RF-0668-04).
Nov 21, 2009 | Haier BC112G Wine Cooler
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
Jun 25, 2008 | Refrigerators
U-Line 15WC wine cooler not working
First make sure your condenser is clean and the fan is going. If everything is running and still doesnt cool enough then you need a repair person to check the sealed system.
Feb 02, 2008 | U-Line 15WC Wine Cooler
Refrigerators Logo
337 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
