Question about Maytag SAV2655A Top Load Washer
Washer won't spin anymore
The last time I used it, there was a smell of burnt rubber. My clother were still soaked. It also made some strange noises before it stopped working.
  • Mr Vidalia Nov 23, 2007
    Thanks Amigaman! Will those parts cost a lo of money? That transmission sounds expensive. How difficult would it be to complete this repair?
  • 248 Answers
Was it getting loud in spin prior to this?
If so, based on past experience with this model, I would say you need at least a triple lip seal, belt and possibly a transmission.
Posted on Nov 22, 2007
  • Gerald Griffin
    Gerald Griffin Nov 24, 2007
    The seal and the transmission repair require special tools. Both repairs are expensive. Experience with this machine is that you might be better off replacing.
Has a burnt smell, and makes a noise.
yes or a burned out motor coupler if its direct drive
Mar 31, 2015 | Washing Machines
My car is hard to turn, it makes an awful noise and is smoking, it smells like burnt rubber, if i continue to drive it what will happen
Hi Debbie,
Not sure with out looking at it, But from what you posted if hard to turn
sounds like your power steering punp aint working , ant if smoking and smells like burnt rubber sounds like pumps locked up, (pully not turning) and if so continuing to drive it could leave you on side of road if it runs a cerpintine belt , that kind of belt runs every thing and if breaks water pump stops flowing water motor will over heat, you should realy have someone look at that for you.
Feb 05, 2014 | Dodge Cars & Trucks
2001ford escape burning rubber smell and noise
Check the rear upper strut towers. These are notorious for rusting out, and causing the tire to hit the inner fender well. To my knowledge, no recall on this, but I've fixed a few with a rear quarter panel replacement from rock auto. You wouldn't notice it much on the rear of the vehicle. Smell the rear fender wells for burnt rubber odor.
Apr 03, 2017 | Cars & Trucks
2001 ford escape has horrible rubber smell and bad noise
Remove the drive belt on the alternator and see if you can spin the pulley freely. Check for bearing noise or knocks in the alternator . If it is hard to turn then replace the alternator . While the belt is off check all other units and pulleys to see if they turn freely. Now check the drive belt and smell it If it smells of burnt rubber then replace it as it is what the smell is all about.
Feb 03, 2014 | Cars & Trucks
2000 Ford Escort, oil light came on then lost all gas power and my car would not go over 40 miles an hour. Then my car died and white smoke came out from under hood. I smelt a strange smell before all
gonna guess that the timing belt slipped or broke due to low oil pressure up top..what was the odor..burnt oil. burnt antifreeze or burnt rubber..or did it burn your nose like an electrical fire..repost please
Jan 17, 2013 | 2000 Ford Escort
Low humming noise and burnt plastic smell coming from 1990 acura integra
Jennifer what type of timing belt does your engine use ?
Is it Nylon ? When was the last time you had it changed ?
Burning plastic smell may be being caused by the timing belt bearing runners seizing and the belt is getting hot .
If the belt is due to snap you could cause a lot of damage to the engine if it breaks.
Might be worth getting a mechanics advice on this as a possible cause
Mar 04, 2017 | 1990 Acura Integra
Electrolux cylinder vacuum No suction and loud noise and smell of buring rubber
rollers are probably stuck the belt is burning check for restrictions in you hoses as well as in the vacuum as well if nothing else works a repairman
Jul 13, 2012 | Vacuums
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag SAV2655A Top Load Washer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
