AT indicator on column damaged or broken, does not register.
SOURCE: I have a 1993 Olds 88 that is stuck in neutral.
do not touch the column. the cable is attached to the bottom of the shift lever and on the trans. find out which end is bad and go from there. most likely you will need to replace the cable but ck both ends first.
SOURCE: I have a 2001 for ranger. The shift indicator
You will need to go to a Ford dealership and first get the part. The remove the radio's center trim panel. two screws are hidden at the bottom. Removet that panel the remove all screws that hold in the cluster trim. After the trim is removed, remove thecluster screws. You will see the cable which leads into the shift bowl. That is what is removed and replaced
Testimonial: "Thank you very much for the solution. By followiing your directions, I had the truck repaired in less than two hours. You Are The Man!!!"
SOURCE: 1997 grand marquis has shifter
The shifting linkage is worn. The linkage from the column to the transmission is loose and will need replaced to get the indicator to read the proper gear that you are in. Is the shifting loose? Or does it still seem like it is tight? It could be also be the gear positioning sensor has been moved out of position. If the shifter seems loose then it would be the linkage. If it still seems tight then it should be the sensor.
SOURCE: Column shifter does not make the gears change, indicator moves from P to D and nothing happens
Sounds like your cable has broken or come off on the side of the transmission this is your problem it snaps off and on under the vehicle. and if the linkage is intact and moves it is the electronic module on the side of the transmission behind the shift cable.Remember to rate my solution and give testimonial this is how i earn my achievements here on FixYa Thanks in advance if you need further help just ask
