Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES0 not heating -- How do I check and change the fuse?
    Problem Solver:
  • 9 Answers
Use a ohm meter, remove 1 of the wires from fuse, take your both leads from your meter and touch each one on the fuse, If you are showing OL, means its bad, If its giving you a reading then its something else.
Posted on Jul 27, 2009
Frigidaire Dryer GLEQ2152ES0 counts down almost in seconds.
Sounds like a board communication problem check and spray connections
Feb 18, 2015 | Frigidaire GLEQ2152ES Electric Dryer
What might be wrong with my gallery dryer #gleq2152eso it does not heat?
Hi friend, I appreciate your post!
Based off the information you have provided your Frigidaire dryer, GLEQ2152ES0, is no longer heating. I understand that you heard a noise like pennies hitting the drum and then it stopped heating. Some possible reasons to why your dryer is not heating could be that your vent is restricted, an issue with your thermostat, or heating element. I would recommend having a technician come out to diagnose and repair your appliance because with the noise you heard he may need to disassemble the dryer. I hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire Dryers
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
My frigidaire dryer GLEQ2152ES0 runs but no heat and the lights all blink
bad heating element check with multi meter first? check ur thermostats also. lastly may be not getting full 240 at the terminal block
Jun 09, 2014 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Frigidaire GLEQ2152ES0 GETTING TOO HOT
Most likely a bad temp control or a broken fan. The control is mounted on the blower housing. To access READ MORE
Jun 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire gleq2152es0 dryer will not heat up. Runs just no heat.
At most you may find a relay in a dryer. They're usually wired pretty simple. Keep in mind that 220 comes from both wires, and meets in the middle, the load. Be careful if you test live! A control may break just one wire. At a failed component, you'll have 220 on both legs, but no go. Jumping that component will make the unit run. Don't jump the elements!!! You can put a false load where the elements go, but it must be 220 volt, like two lite bulbs in series. I make my tester out of two lite bulb pigtail fixtures wired in series. At 110 they glow less bright then at 220.
Apr 21, 2009 | Frigidaire GLEQ2152ES Electric Dryer
FRIGIDAIRE GLEQ2152ES0 DRYER DRUM WILL NOT TURN
You need to check the motor isn't bad which is possible. All of what you have stated is possible. You are going to have to check out each and every one until you find it. But all three can cause it.
Apr 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
470 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
