Question about Dometic RM2652 Refrigerator
Dometic RM 2800 Works great on AC but not on LP
Just got an older Motorhome with a Dometic 2800. Fridge works great on AC and the thermostat seems to respond just fine on AC. However when I switch to LP, the pilot will light just fine. I can see it when I look inside, but the burner never seems to fire. I worked the thermostat back and forth. Made sure that the line was getting proper pressure, and yes...also made sure my LP tank was full. Hmmmmmmm.....can't figure it out. If anyone can lend an assist i would greatly appreciate it.
  • Dometic Master
  • 6,674 Answers
You say that on LP the pilot lights and you can see it. You don't have a pilot on that fridge. If there is ignition and you see a flame under stack, that is the burner. It certainly will not be a big flame as you would expect to see in a furnace, only a small flame approx. 1" high x 1" wide, from burner tube, and should be centered under the tube/stack/chimney, whatever you want to call it.
Posted on Nov 13, 2011
    Problem Solver:
  • 6 Answers
Most likely cause is a blocked gas jet in the main burner its rare for the thermostat to be faulty but you cant dismiss it
Posted on Jul 27, 2009
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
Dometic refrigerator model RM 2193 for RV works only in the DC and LP Gas mode. two days ago the AC mode was still working and stopped yesterday (outside temperature was about 40 degrees...
Hi and welcome to FixYa, I am Kelly
Operators manual:
http://www.gas-refrigerators.com/pdf/RM2193-manual.pdf
Parts manual:
http://www.scamptrailers.com/Portals/0/Dometic_Refrig_RM2193_PartsList.pdf
If you look at the last page of the parts list (page 10) it is showing a thermostat across the Black and white wires.
There is not a fuse that I can see. The fuse has to be external to the unit. You should be able to read continuity (resistance) of the AC heating element at the power cord with the AC switch ON.
AC Power source must be removed to perform resistance checks.
No continuity there are 2 possibile failures (Other than wiring)
1. AC heating element
2. Thermostat.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | Dometic Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
I just replaced the converter in my motorhome and everything works but the fridge won't work on house electricity, only gas ???
The old converter may have blown out the control board for your 'fridge. This is quite common if the voltage exceeds 15.5 volts, and when there is a ripple voltage (AC voltage component) riding on top of the DC voltage.
Gas / LP mode is the default for this fridge, a fail safe mode.
You can find the service manual for your fridge here.
Jul 08, 2010 | Dometic RM2652 Refrigerator
Dometic RM 2800 Refrigerator will not cool. freezer is some cool. this is on LP gas
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Jul 12, 2009 | Dometic Refrigerators
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
May 18, 2009 | Dometic RM2620 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
592 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
