SOURCE: Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
SOURCE: i have a dewalt dc011 radio, it will not charge a
Sorry to say the unit has a short in it, You need to have it serviced to fix the problem.
Testimonial: "thanks, just had it looked at it's the charging unit thats gone £80 to fix :-( "
SOURCE: my dewalt dc011 wont work..it charges and when i
i have the same problem, did anyone find a solution?
SOURCE: did not recieved operators manual with dewalt
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
SOURCE: I bought a dEWALT DC011
Your radio/charger is equipped with memory capacity in order to store the time and your selected memory channels. When the radio is in the OFF position, this memory capacity is powered by two (2) AA batteries.
Please check these and replace all both pieces if they would be weak.
Thanks.
gylacz
