I have a 58 inch plasma and my TV has started blacking out. When I turn it on the TV operates fine. After about 20 min the screen will black out but you can still hear the sound. The sleep setting is turned off and the cable is fine.
    Novelist:
  • 133 Answers
The fault you describe (the unit blacks out after it heats up) suggests that there is either a bad solder contact on one or more components or connectors inside the TV or partial damage to some semiconductor (or other) device(s) in the video section or the power supply for that section (since the sound remains functional, you probably don't need to look into that).
This could be a voltage regulator, a power transistor, possibly also other things like diodes, capacitors, resistors, inductors, connectors (actually, just about anything).
See if any of the circuit boards looks darker / brownish / burned around any components (check both sides), these are the areas that are the most likely to have a bad (partially desoldered) contact.
If there are mostly surface mount components, the solder around pins may look somewhat dull, oxydized and wrinkled. Also, it's harder to spot bad solder contacts on the surface mount components than on the thru-hole mount components.
Anyway, a good solder contact is clean, normally shiny, and the solder is more or less equally distributed around the component pin right to the edge of the solder tab.
A bad contact will many times show as a thin, dull grey ring in the solder around the component pin, some halfway between the pin and the outer edge of the solder tab.
Some of these can be difficult to spot, so you may need a good light source and possibly, a magnifying lens. Many times, there is very little or (almost) no change in the colour of the circuit board around these (they didn't heat up much yet).
The bad ones are easier to see, as the ring is more pronounced and if you grasp the pin with a pair of tweezers and move it around a bit, you'll see that the ring is actually a crack already, also the circuit board has probably changed to a darker colour around these.
The really bad ones are the easiest to find, the crack is readily visible or worse, the pin is (almost) entirely desoldered by heat, and the circuit board has clearly become brown(ish) around the solder tabs.
To fix this, remove the old solder with a solder pump, clean the tab with ethyl or isopropyl alcohol and the pin with a scalpel, then resolder.
Hopefuly, if there is no real damage to any of the components (apart from some cooking), this should help, but if it doesn't then you'll need to check the components (beginning with the ones you had to resolder as they are the most probable candidates to be the cause for the malfunction).
I hope you can get your TV back to life...
Good luck
3rq8 (Triarcuate)
Posted on Jul 27, 2009
How to fix Samsung 58 TV display got half black curved line?
Hi Mazy, sorry to hear about this...
Problem with plasma screens is that they do have a limited life, they also do not like to travel. You have to keep them upright because the glass panel is so heavy. Did you lie it flat for transportation? Is the black area in the middle bottom or in the corner? If it is in the corner, and the mounting point has a problem, it could cause this, but hard to say without seeing it. Does the black area retreat when it is off and cools down? I doubt if it is the system board, sadly if it is the display panel, it would not be worth fixing.
Let me know if you have more details... Good luck.
Nov 14, 2014 | Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
My 58 inch Viera has ghosted black lines radomly appearing after being on for 20 to 30 minutes. Where should I start.
It should be due to its Y-Sustain and drive boards. Just enter this site named 'Electro-help'. You can see so many problems that can occur with Panasonic plasma TVs and description related faulty boards . Try this link and select the site. Pull up older posts there.
Jul 18, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
My plasma tv has blue or black spots (scattered on tv screen) when it is on about 30 mins to 1 hour then as it on for long hours it becomes black spots and covered whole screen
I am facing the same problem with my LG 32 inch plasma TV. There is also a big 2inchX4inch oval black spot at the top centre of the screen. Please suggest any remedy and also the cause. mbkhurshid@gmail.com
May 17, 2010 | Televison & Video
I have a 4 yr old LG 50PX1D plasma tv and it works fine for about 20-30 min then the screen goes black. If you turn it off for an extended period, then back on, you can watch for another 20-30 min. Any...
Its either the XYZ circuits, power supply, or bad ESR conditions starting to develop. Have your local shop repair it for you....
The set is 4 years old, and usually problems in Plasma tv's develop before then......
Nov 17, 2009 | LG 50PX1D 50 in. Plasma Television
Panasonic TH58PX600U 58 in. HDTV Plasma. Image is Distorted
I could not see the image you say you included in your description. If the rectangle is black (and not just an outline) it may be the box associated with captioning or text descriptions. Use your setup menu or remote control to turn captioning/text off.
Oct 09, 2008 | Panasonic TH58PX600U 58 in. Plasma HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Jan 10, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
