Question about Baby Lock Ellure
Bobbin thread tangling up
I have a problem with the bobbin thread bunching up and causing the needle to sew in one spot then I have to stop the machine and cut the underneath of the fabric to free up the hoop and fabric then pull out a wad of bobbin thread. Then after I free that problem and start it back the hoop seems to be out of alignment so my design if off.
  • 55 Answers
Are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Posted on Jul 27, 2009
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
Why isnt my bobbin thread being caught by the upper thread?
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?
May 24, 2015 | Sewing Machines
Y does my top thread pick up on hook and when it catches bobbin thread it gets tangled up on top of bobbin
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? v
May 21, 2015 | Sewing Machines
Needle dragging in bobbin casing. How do I adjust needle shaft?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? wwww
May 16, 2015 | Singer 8763 Curvy Electronic Sewing...
Needle not picking up stitches
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? o
May 16, 2015 | Janome Sewist 525S Mechanical Sewing...
How do I sync the rhythm of the needle on my sewing machine with the bobbin spinner?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? mmm
May 16, 2015 | Sewing Machines
How do I thread it and fill and thread the bobbin?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? vv
May 15, 2015 | Sewing Machines
How do you put a needle in it?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? cc
May 11, 2015 | Sewing Machines
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
Burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Jul 16, 2009 | Bernina Bernette 75
Sewing Machines Logo
781 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
