Question about Bose Wave Radio
60 Cycle Hum
When the radio is on a 60 Cycle Hum can be heard, regardless of the radio volume setting. Sometimes the amplifier turns on by itself and emmits the same noise. (Radio is not playing)
Does anyone have a schematic?
  • 5 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
0 characters
1 Points
My speakers hum even when volume is set at lowest setting and static noise after it has been turned off, how do I fix it?
This isn't really a solution, but it does work. Mine does the same thing, and I found on another forum, some one suggested that once the power is off and it starts to hum. Smack the back left top (as your are facing it) and it will stop the buzzing. I was hesitant at first, but after many fruitless searches, I gave it a try. It does work, but you have to hit it fairly hard and it may take a couple tries to get it to stop. I still can't believe no one has found a solution to this, it seems to be a common problem. If someone is a tech person, please way in on this, I am willing to take this thing apart, I just don't know what to look for. It appears that they use relays to delay the time for powering on and off the amp, once the 2-3 second delay is over after powering off, the speakers buzz loudly with a static noise.
Aug 31, 2013 | Boston Acoustics Duo-i Horizon Clock Radio
I must have pressed the wrong button on my old but excellent Proton 320 clock radio because the radio no longer comes on at the time set on its alarm. The radio is fine when I just turn it ON; it goes...
when you set the alarm it is activating by itself ...see that you have the button that will set it to go to radio or buzzing noise..and in the back it has a knob for a separate volume on the alarm I think this is what you have lower and the alarm is not heard even if it kicks in ..
let me know if that is the issue or I should see further ..
Jan 23, 2011 | Proton R5A Clock Radio
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Dec 09, 2010 | Bose Wave Radio
How can I set the timezone on my Sentry self-setting atomic clock?
Many Sentry product manuals can be down loaded from the following URL
The instructions for Sentry CR104 is located at the following URL
I have noticed sometimes the instructions tell you to use the ADJUST key.
If that does not work try the SET key sometimes it will work instead of the ADJUST key.
Jan 09, 2010 | Sentry CR104 Clock Radio
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Are you listening to AM or FM? If you are listening to AM, trying rotating the radio. You may be picking up some type of local AM interference. If it's happening on FM....then I guess there is always a possibility that you may have a defective power supply and what you are hearing is the hum from that.
Nov 04, 2008 | Bose Wave Radio
Volume is locked
thank you soooooo much!!!
it worked :)
Sep 01, 2008 | Boston Acoustics Duo-i Horizon Clock Radio
Mar 07, 2008 | Bose Wave Radio
How to set alarm and ring with radio?
Hi gidgid.
This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
1. Press [ALARM] to switch to display the alarm setting.
2. Select ALARM 1 or ALARM 2 using [ALARM].
3. Press and hold [ALARM] for two seconds.
4. Use VOLUME [ + ] / [ - ] to enter the hours.
5. Press [ALARM].
6. Use VOLUME [ + ] / [ - ] to enter the minutes.
7. Press [ALARM].
8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
ALARM is selected, a two-minute crescendo alarm will be
emitted at the set time when the alarm is active. If RADIO is
chosen, the radio will be turned on for two hours at the set time
9. If RADIO is chosen, use [STATION] to choose the radio
station and press [AM / FM] to select AM or FM.
10. Press [ALARM].
11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
12. Press [ALARM] to exit.
Note: If there is no battery for the radio, there is no operation for
step 9 ~ 11.
sleepy head
Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
Alarm Volume
Jan 23, 2007 | GE 7-4897 Clock Radio
Bose Wave Radio Logo
115 people viewed this question
Top Bose Clock Radios Experts
Sheila Brown
Level 1 Expert
Are you a Bose Clock Radio Expert? Answer questions, earn points and help others
