A friend took chain off and reset it either up a tooth or back a tooth and i set the timing correctly by manual. i can tell that the time is correct or almost correct because it finally sounds like it is supposed to while motor is turning over. but it is flooding . i have checked spark, its good, i have drained gas from bowl with drain hose, can the chain being moved up or back a tooth even with the timing set as it requires , make it not crank . how do i fix this please
If it is firing and the spark is good it has to be the fuel system. Check the carb you just put in(make sure the gaskets are sealing and all the air ventilation holes are not clogged). also the air intake system. It is usually located around the carb connected to a hose or other rubber related system. You may have a leak somewhere. All you are getting is fuel and no air to balance out the fuel.
SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
SOURCE: 2001 pt cruiser limited won't crank
needs a battery but be careful cause sometimes a bad alternater will cause the battery to go bad
SOURCE: 01 Dodge Intrepid with 2.7l V6 turns over but
The coils only power up during cranking check that first. If it sounds funny cranking,ie. cranks faster or slower than usual,then he's probably right about the timing belt. If it jumped the heads need to be replaced or rebuilt,both costly. Would be cheaper to put a used engine in.
SOURCE: 2001 Chevy Malibu, 89,000 miles, 3.1 engine, won't start
CLICK HERE for the injector schematic.
CLICK HERE for the Ignition schematic.
Since the PCM uses info gatheres from the crank and cam sensors to calculate ignition - and there are no OBD codes - in all likelihood, the PCM itself is bad.
The Ignition Module, also transmits to the PCM.
It appears after all your testing - that the PCM is at fault.
It does not error report on itself (unfortunately).
The ignition timing is controlled by the Powertrain Control Module (PCM). No adjustment is necessary (distributorless ignition) or possible.
Please see the following....
The ignition timing is controlled by the Powertrain Control Module (PCM). No adjustment is necessary or possible.
The engines covered by this manual are equipped with distributorless ignitions, ignition timing is controlled by the Powertrain Control Module (PCM), as applicable. No adjustments are possible. If ignition timing is not within specification, there is a fault in the engine control system. Diagnose and repair the problem as necessary.
Ignition timing is the measurement, in degrees of crankshaft rotation, of the point at which the spark plugs fire in each of the cylinders. It is measured in degrees before or after Top Dead Center (TDC) of the compression stroke.
Ideally, the air/fuel mixture in the cylinder will be ignited by the spark plug just as the piston passes TDC of the compression stroke. If this happens, the piston will be at the beginning of the power stroke just as the compressed and ignited air/fuel mixture forces the piston down and turns the crankshaft. Because it takes a fraction of a second for the spark plug to ignite the mixture in the cylinder, the spark plug must fire a little before the piston reaches TDC. Otherwise, the mixture will not be completely ignited as the piston passes TDC and the full power of the explosion will not be used by the engine.
The timing measurement is given in degrees of crankshaft rotation before the piston reaches TDC (BTDC). If the setting for the ignition timing is 10 BTDC, each spark plug must fire 10 degrees before each piston reaches TDC. This only holds true, however, when the engine is at idle speed. The combustion process must be complete by 23° ATDC to maintain proper engine performance, fuel mileage, and low emissions.
As the engine speed increases, the pistons go faster. The spark plugs have to ignite the fuel even sooner if it is to be completely ignited when the piston reaches TDC. Spark timing changes are accomplished electronically by the engine and ignition control computers.
If the ignition is set too far advanced (BTDC), the ignition and expansion of the fuel in the cylinder will occur too soon and tend to force the piston down while it is still traveling up. This causes pre ignition or -knocking and pinging-. If the ignition spark is set too far retarded, or after TDC (ATDC), the piston will have already started on its way down when the fuel is ignited. The piston will be forced down for only a portion of its travel, resulting in poor engine performance and lack of power.
Timing marks or scales can be found on the rim of the crankshaft pulley and the timing cover. The marks on the pulley correspond to the position of the piston in the No. 1 cylinder. A stroboscopic (dynamic) timing light is hooked onto the No. 1 cylinder spark plug wire (2.2L engine only, on the 2.4L engines, special adapters are needed) . Every time the spark plug fires, the timing light flashes. By aiming the light at the timing marks while the engine is running, the exact position of the piston within the cylinder can be easily read (the flash of light makes the mark on the pulley appear to be standing still). Proper timing is indicated when the mark and scale are in specified alignment.
WARNING
When checking timing with the engine running, take care not to get the timing light wires tangled in the fan blades and/or drive belts.
Thanks for using FixYa!!
SOURCE: 2002 Pontiac Sunfire is out of time, how do I adjust the timing?
The timing is not adjustable. You must get the system scanned for codes to diagnose this problem.
