SOURCE: missing instruction manual
here is where to get the instruction manuals for the omron healthcare blood pressure monitors. You just select your model number and either view download or print from the website. Good Luck and God Bless!!
http://www.omronhealthcare.com/product/manuals.asp
SOURCE: The voice stopped working on the talking blood
This usually happens when the instrument is too embarrassed telling you your BP!
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com
SOURCE: I need to register my
Here you go, Jim. http://lifesourcecanada.com/register.html
Hope this helps you. Please be kind enough to rate my response to you. Thanks!
Testimonial: "Thanks for your prompt response. It was exactly what I requeste."
SOURCE: Neither of the cuffs
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
