Question about Acer Aspire 4315 Notebook
Have DIMM1 512MB RAM-what is highest avail RAM to update - Only 1 input for card
  • Acer Master
  • 32,281 Answers
You need to check the specs of your laptop to see what is the maxium amount of RAM your laptop can support.
Although you can see one DIMM slot there may be another under the keyboard that already has a DIMM installed.
DIMM are avail in up to 4Gb most common 1Gb and 2Gb.
Posted on Jul 27, 2009
My computer has no display even my RAM is new,,how to fix this
could be the video cable, video card, motherboard, monitor input settings or monitor hardware failure. start with swapping the monitor cables, then swap the monitor, then look at the video card (see if you can update the driver or swap the video card).
Apr 05, 2014 | Computers & Internet
I have asus vw192t 19"
Resolution capabilities are a complicated blend of the abilities of your graphics card and the abilities of your screen. You will not always get a 1:1 match. You can improve your chances by installing the "monitor information" file that is usually supplied on a CD that comes with the monitor. Also, updating the drivers for your graphics card (see the manufacturer's web site) might help.
Mar 23, 2011 | ASUS VW192T Monitor
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
My motherboard is IntelD845PESV. i use 512 mb DDR 1 RAm & 64 mb Nvidia Geforce 2 Mx/Mx 400 AGP card. Now, i want to upgrate the AGP and RAM . In the intel site maximum RAM supported by this...
Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
Hope this helps.
Nov 09, 2009 | Intel D845PESV Motherboard
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Game not working due to less video memory
Restart your computer and your friend's computer, at the same time. Press <DEL> to enter BIOS-setup on each computer.
Do both computers show _exactly_ the same amount of RAM?
One BIOS-setting may allow you to "dedicate" some of the RAM to be used for "video-memory". Do both computers show the same amount of "dedicated" RAM?
Jun 01, 2009 | Lenovo 3000 V100 Notebook
Trying to connect 3 gig sticks to my p4pe motherboard, only works with 2. also new video card runs at 512mb, in bios it only allows me to select 256 can this be adjusted through update or do i need 256...
Even though there are three sockets, this board supports a max of 2GB of RAM, sorry.
The AGP Aperture setting in the BIOS does not reflect the maximum amount of usable video RAM on the card, so don't be concerned about that (and in fact you shouldn't need that to be higher than 128M).
For the hard drive, you have your terminology mixed up. There are two IDE adapters on your board; A primary and secondary, each with two available assignments for the devices connected which are called 'Master' and 'Slave'. If your primary adapter already has two devices and your secondary has only the DVD drive configured as 'Slave', than you can connect a new drive to the secondary adapter configured as 'Master'.
Hope this helps!
May 28, 2009 | Computers & Internet
Clicks
try to change the clock sync in the sound card to independent
Mar 26, 2008 | M-Audio Delta 1010 Sound Card
Acer Aspire 4315 Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
