Question about Whirlwind FH-778 Air Conditioner
Heavy exhaust smell from A/C
For the past week and a half I have had a very heavy exhaust smell in my apartment, which seems to be coming from the A/C vents. It leaves a bitter taste in my mouth and burns my eyes. This smell also gives me awful headaches. It is stronger right after the A/C kicks on, and right before it switches off. I have a combo Lennox A/C and furnace. I had a maintenance man come and he changed the filter, which was filthy (apartments responsibility, and I've been here two years and it has never been done, and I never thought to do it before). He looked and could not find a problem in the A/C, vents, no bird's nests, etc. The smell got worse. I called the gas company (no CO leaks supposedly) and they found what they called a 'small' gas leak, which was supposedly fixed by maintenance. The smell went away for almost a day after the repair took place. Now it comes and goes again with the cycling of the A/C. It does not smell like natural gas. It smells like auto exhaust. There was no idling auto outside anywhere when the smell started, and has been none since. We have no attached garage. Today I got so frustrated with the smell, I opened the furnace/A/C and hot water heater closet to vacuum out the lint and dust which was abundant. At that time, I noticed that there are three copper looking lines coming or going, from or to the A/C unit itself. All are leaking a clear oily substance. One has water condensation, yet all three are oozing oil at the connections. Is this normal? Because the maintenance man told me he checked EVERYTHING, yet as soon as I opened the closet door the leaking lines were right in front of my face. The maintenance man and the two gas company techs told me that a gas leak would not give me a headache, nor would it cause burning eyes and throat. Nobody would admit smelling any exhaust type smell. They have basically told me that I need to go see my doctor and find out why I am having 'phantom' smells. Today I went and got my neighbor to come smell my apartment. He said it smells like spent diesel fuel to him. So, while I have a witness to the smell, I can't convince maintenance that there is a problem. He is supposed to be certified in HVAC, but I am having doubts. How can I convince someone that there is a smell when they can't smell it themselves? Have you ever heard of such a thing from an A/C unit? Any advice will be so greatly appreciated! That you so much for your time. PS: I have an incredibly good sense of smell...always have.
  • emichelle111 Jul 29, 2009
    In this economy many people are willing to take a cut in pay just to make ends meet. So, you have led a very sheltered life if you believe people will not take half their normal pay just to keep a roof over their family's heads, and food on the table. Times are tough my friend.
    Thanks for responding to my query. Sorry you couldn't help.
    PS: Ever heard of Phosgene gas?
  • bud arc Sep 11, 2013
    Did you ever find a solution to this? I am having the exact same problem. I keep worrying they're going to find me dead in my apartment, because of this strange exhaust smell coming through the AC vents that apparently no one else can detect.
I'm having a similar problem but with a home a/c unit. I had every appliance in the house checked, first, including furnace, but no problems were found. I get similar symptoms, many people can't smell anything, a few can. Someone visiting asked me in September if my furnace was on because it was a slight mechanical/ozone-y smell. I'm about to drop a lot of money on a VOC test because this has been going on for 8 months with no solutions.
It's cold comfort, because I have no solution, but if I figure out what my problem is, I'll post it here, too.
Posted on Oct 26, 2013
    Problem Solver:
  • 14 Answers
First of all, I work around maintenance men alot. I am an HVAC tech and if it is one thing I've never seen is a maintenance man certified in HVAC. It takes a college degree and if he had one he wouldn't be working as a maintenance man for 1/2 the pay. As for your
"leak" All a/c systems in residential applications use refrigerant to remove heat and cool the inside coil in your air handler/furnace. The gas is non toxic, non smelling and will only give you a headache if you inhale high concentrations (you'd have to be doing this intentionally ie...huffing). As for seeing an oily substance around the fittings on your refrigerant lines. No, this is not normal, unless the maintenance man sprayed soap bubbles and you think it's oil. Soap bubbles are commonly used to detect leaks in sealed systems (a/c coils and fittings). If, in fact it is oil, that is a sign of a leak but generally to the untrained eye, it is harder to spot this oily substance, it is usually best spotted because dirt sticks to the oil and techs recognize that. There is virtually nothing in an a/c and furnace that would result in what you are discribing. Everyone knows what natural gas smells like and if the man had a meter...
Posted on Jul 29, 2009
  • FNGHVAC Jul 29, 2009
    The pay thing was meant to reflect the economy in whatever shape. My point being made was that many maintenance men say that they are HVAC certified when in fact they know only very basic things which sometimes lead to bigger problems with systems and often times have never had any schooling in the field. I speak from experience. And, yes I know what Phosgene gas is. The gas is only present if the refrigerant is being burned by a high temperature flame such as oxygen and accetelene mix or a mapp gas torch. It is deadly and will cause headaches when breathed, but then, unless you have a torch set burning away in your vacuum closet on the exact spot where a refrigerant leak is occuring this is absolutely impossible. Good luck!
What could be causing my f-150 to smell and white smoke coming from engine after driving it at highway speeds and feeling like towing heavy load? 3 different shops and no one knows what's causing it?
Most people associate white smoke as a blown head gasket but I had a Ford that was dumping fuel and it had heavy white smoke and stunk out the exhaust. It had bad injectors. Let your mechanic read your fuel trims on his scanner after a long highway drive. Or do a fuel leak down test on them to know for sure.
Jun 05, 2015 | 2005 Ford F-150
Car started smoking heavy fuel smell coming from exhaust and idles rough
White smoke is water in the cylinders/exhaust. (bad head gasket) White with a bluish color is oil. Black smoke is to much fuel. Which do you have.
May 19, 2015 | Cars & Trucks
Dryer is squeeking and does not tumble on heavy loads
It sounds like the belt is gone....
Also check out this tip about your problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Mar 28, 2010 | Frigidaire Dryers
Issues with 99 Chevy Blazer LS
check the exhaust manifold possible gasket,check flange gasket or check exhaust system for damage --cat converter smells like rotten eggs or if plugs up stalls vehicle and wont let start-----
Feb 13, 2010 | 1999 Chevrolet Blazer
Heavy exhaust smell from A/C Solve For the past week and a half I have had a very heavy exhaust smell in my apartment, which seems to... (More) For the past week and a half I have had a very heavy exhaust...
if you see oil "oozing from the copper lines (fittings) you can verify if refrigerant is leaking out of the lines using a solution of dish soap and water, spray or wipe the solution on the suspected leak, and if it is leaking it will bubble. if it is indeed leaking the smell of refrigerant could be described as "exhaust" usually the smell is described as "chemical" by clients that I have served in the past. I have never heard of refrigerant causing headaches, as refrigerant is considered as non-toxic. It will dispalce oxygen in large enough concentrations, but it would take considerably more than a standard system holds to displace enough oxygen to cause issues, unless it was all released at the same time. hope this helps
Jul 27, 2009 | Heating & Cooling
Engine light on, heavy smoke and engine burning smell (Audi 1.8T)
First off, how the Hell did they issue a DOT Cetificate, if the Emissions are known to be off the clock. Without causing stress, do you have, or can obtain the Emission Test Result Print Out from the Testing Station test Equipment. This is something they cannot refuse. DO NOT AUTHORISE ANY REPAIRS Come back TO ME with your story.
Regards,DT
Jul 02, 2009 | 2000 Audi A4
Audi 1.8T sport Auto (2001) heavy smoke and engine buring smell
The engine could be shot, oil is being burnt off by the actions of being sucked into the bores via worn piston rings then ejected out of the exhaust
If you sent the car in for an MOT and a Service I would ask the garage what they did to it as the car would have failed on its emissions test if that much oil was coming out .
It could have been a fault on the oil pump or lack of oil in the first instance and maybe an overfill on the service
You paid your money now go back for redress
Heating & Cooling Logo
1,600 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Bill Long
Dan Webster
Dan Webster
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
