Question about Amana Dryers
My amana gas dryer (model # lg8519w2)has an
My Amana gas dryer (model # lg8519w2) has an intermittent heating problem. ??????? Help. I'm not too well versed on 120 vac appliances but I am mechanically inclined and know how to use a multimeter and am not afraid to try to fix her. Help.
    Scholar:
  • 84 Answers
First check you exhuast. If you have access to the vent outsid where the vent termintes the check and see if there is no lint build up or make sure nothing is block the air flow to the outside(storage caontainers or anything that will block the airflow from the dryer to the outside)..if no blockage or lint build up, then i would change you gas coil vales. they are located on you gas valve. they are 2 black looking things. But make sure when if you change them,one of them has a metal sleeve that goes on the shaft...make sure you know whick one it came from and slide it back on there..sometime when you take the old oned out, itll come off with the coil. Just take it out and slid it onto the gas valve. Like i said tho, make sure you know whick one it came off from...but yeah, try changing you gas valve coil....if its an amana dryer then there should be that bottom panel to take off and the gas valve should be right there..hope this helps
Posted on Jul 27, 2009
My Amana gas dryer Model NDG7800AWW heats initially and then stops.
Hi Mohit , you need a new set of valve coils . It's part # 5303931775 GOOD LUCK APPLIANCES R'EN
Jun 17, 2014 | Amana NDG7800AW Gas Dryer
I have a Amana clothes dryer model no NDG78700AWW. The dryer tumbles but it is not producing any heat. Any thoughts on the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Amana NDG7800AW Gas Dryer
My amana dryer has not heat. model number LEA50AW
heatman101
Mar 17, 2011 | Amana Dryers
Amana Dryer NDG5805AW heats for a couple seconds after starting then no heat HELP
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Amana NDG5805AW Gas Dryer
Amana dryer does not heat sufficiently
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 27, 2010 | Amana ALG866SB Gas Dryer
Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Jul 23, 2010 | Amana ALG643RB Gas Dryer
Will not heat all the time maybe 1 out of 10 times it might heat up
The most common problem for gas dryers is the ignitor going bad...
This often will be an intermittent problem at first just as you desricbed...
This tip will help you...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Amana ALG331RAW Gas Dryer
No heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Jul 25, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
303 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
