Question about Sony Playstation 3 (PS3) Console
Will not read games or blu-ray discs - Sony Playstation 3 (PS3) Console
  • ripplinger8 Jul 27, 2009
    when i load a game or blu ray disc into player it gives me a disc read error message
  • 10,515 Answers
This is a Major Problem Sony for repair. Many people have already raised Questions regarding this message which cost them many bucks.
http://www.petitiononline.com/PS3issue/petition.html
You can also list yourself as one of the unfortunate one who have this message.
Note - 1% chance is there that it can be rectified by updating the firmware.
Hope i helped you.
Do Accept the solution if 100% satisfied.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 27, 2009
    Genius:
  • 1,689 Answers
Hi ripplinger,
here is a good fix that worked for a gamer
Ok so the same thing just happend to me as well. Aftersearching/finding my receipt, I also found that my PS3 is beyond the 1year warranty. So I thought that instead of paying the $150 I wouldtake matters into my own hands. I found a site that allows you toreplace the Blue-Ray Optical lens mechanism at http://store.videogamecentral.com/ps3-optical-laser-lens-assembly
-repair-part.html.
So I thought if I'm going to buy this and install it then I'm going to have to take it apart anyways.
Here is what I did:
***Warning***Perform this method at your own risk. I would only reccomend this topeople who's PS3's are out of warranty and those who have some sort ofelectronic background.
Unplug PS3 before performing any of these steps
1.If concerned with warranty sticker then remove the warranty stickerintact by using a blow dryer using hot air and gently remove thesticker.
2. Remove plastic piece and the Star screw and Slide the outer lid off the PS3
3.Underneath the outer lid there are a few Phillips head screws toremove, now remove the second shell by lifting from the back of thelayer and pull forward towards the front of the PS3.
4. By now you should see the Blue-Ray Disc Drive on the right side of the PS3
5.Remove the connector wire and ribbon connecting the BR-Drive, one isvery small and should just jiggle out while the other is underneath thedrive, it can be removed by using a small flat screwdriver tolift up the black piece holding in the small ribbon.
6. Now youshould be able to easily remove the 4-5 very-small-black phillipsscrews holding the silver metal crate that is attached to the driveitself, lift off the crate.
7. There should be only a fewmore phillips screws hold the top of the BR-drive together. Once youremove these the laser should be exposed. Be sure NOT TO TOUCHANY OF THE MECHANICAL PARTS if you can help it especially the laser.
8.Take a Q-Tip and dip it into alcohol being sure not to over soak theQ-tip, and gently clean your laser. Use care here as you only want thealcohol to touch the lense. Try not to move the lense at all.
9.Since the PS3 was very simple to take apart I decided to try it outbefore I completly put it back together by plugging the BR-Drive backup and plugging in the PS3 to see if it would read my discs.And of course it read any disc I put in.
10. If it works, then of course put everything back together and GAME ON.
Note: This may not be a perfect fix for everyone but, it sure worked for me.
more in this thread.
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=2698117
hope this helps
regards.
voodoo
Playstation 3 not playing games but will play blu ray discs
Make sure that your firmware is updated correctly. Also make sure the games are the correct region for the unit you're playing on. You may have an incorrect region setup on the PS3. PS3 games are region locked, either being PAL or NTSC. If the PS3 is set to read PAL (by being set to a region that is PAL, like the UK, Europe, and Japan) it will not read or play an NTSC disc.
Misconfigured or corrupted firmware installations can also cause this problem. Furthermore, pirated games will not play, because they do not have the appropriate security key on the disc.
You can try testing this by creating a new profile on the PS3 and trying to play the games. If you can play them with the new profile, then there is a corruption with the old profile. If you can't play them in the new profile, then it could be the firmware.
Lastly you may have a blown drive. Most PS3 games are dual layer blu ray discs capable of storing large amounts of data. The blu ray drive in the PS3 uses a sequenced dual laser to read the game. If one of the laser emitters has blown, it won't read the game correctly. However, since it doesn't use both emitters to read blu ray movie disks or dvds they'll still play correctly.
Oct 04, 2014 | Sony Playstation 3 (PS3) Console
My ps3 wont read the disc
First you should try getting a blu ray disc cleaner. This will clean the lens and let you know if it is dirt is on the lens causing the disc not to read. If this does not work they you will need the blu ray lens replaced.
Blu ray lens cleaner
Mar 25, 2011 | Sony Playstation 3 (PS3) Console
My ps3 will not read my disc sometimes and other times it will read it but it will not work
The disc may be quote, "Corrugated", hence the laser is having a hard time following mis ~ aligned structural pattern. Try to use a CD ~ Lens Cleaner. :)
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
Disc Read error
A disc read error means you will need a new Blu-ray drive. A blu-ray drive can fail to read Blu-ray but play DVD or CD OK. (Or any combination) A new blu-ray drive requires calibration. Contact Sony for the service center you can send it to. www.sony.com
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 wont read the game discs
blu ray or dvd try and see if a dvd will work games and movies will say on disc blu ray or dvd
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
PS3 not reading discs.
Hey man, you can try this....
1. download and install a psn game or game demo
2. put in the disc of the game or video you want to play or watch
3. load the psn game or demo as if you were going to play it
4. quit the demo as soon as you get to the start menu of it
5. go and play or watch the game or video you wanted to, sucka, cause it works now!!!
I hope this works for you, and if it does, spread the word!
Feb 21, 2010 | Sony PlayStation® 3 (80GB) Console
I am trying to copy a ps3 game to my computer,but the dvd drive in my computer wont read the disc.Any ideas
The playstation 3 game format is in Blu-ray... but also a special format of Blu-ray to keep people from making illegal copies of the disc. Also the disc is formatted in a way that a PC will not recognize the disc unless the drive has been modified illegally. A standard DVD drive will not recognize a Blu-Ray disc.
Nov 08, 2009 | HP LightScribe dvd640i (DVD640I)...
Problems with Blu-ray after 3.01 firmware update
you can new discs of blu-ray than no play your game leans problem
Oct 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't read disc
When Blue ray disk is placed into slot it seems like it is going to work and the screen on tv shows the entro for sony but nothing happens. Controls on controller will not function.
Apr 29, 2009 | Sony Playstation 3 (PS3) Console
Won't read any disc
You need a new laser. I have repaired several of these (about 20) with the same problem, wont read discs. The laser can be purchased for $50 online, try ebay.
Jul 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
