Sewing Machines Logo
Annette Smith Posted on Jul 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brother PR1000 and on the test stitch there is too much bobbin thread showing underneath. do I adjust the tension in the top thread or the bobbin tension?
R.A. Ellis
Level 3:
  • Brother Master 12,731 Answers
  • Posted on Jul 12, 2017
R.A. Ellis
Brother Master
Level 3:
Answers
12731
Questions
Helped
2613449
Points
59176
Um, if there is a wad or knot of thread it is bird nesting which is the result of the top thread not being seated completely in the tension disk--it is not an indication that the top tension is too loose or too tight.
Top tension being too loose will allow the bobbin thread to lay in a straight line on the surface of the fabric underside.
When threading the top thread, ALWAYS RAISE the presser foot.
Test your machine.
Adjust the top tension until the top and bobbin threads meet in the middle of the fabric. (Tightening the top tension will bring the bobbin thread higher into the fabric. If it is too tight, the bobbin thread will show on the top of the fabric.)
To help prevent the extra thread at the beginning, begin your first stitch with the needle at its highest point. Hold the two thread tails gently in your left hand while you slowly take the first stitch.
It also helps if you first pull the bobbin thread to the top of the fabric before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Bill Boyd
Level 3:
Top Expert:
  • Brother Master 53,816 Answers
Bill Boyd
Brother Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925423
Points
172802
Adjust the top thread tension as the condition is known as bird nesting and results of the top tension being too loose
Mai Lor
Level 3:
Genius:
  • Brother Master 2,558 Answers
Mai Lor
Brother Master
Level 3:
Genius:
Answers
2558
Questions
0
Helped
524451
Points
7053
Yes Adjust to more tight see what it'll do.
Bottom bobby is too tight or upper thread control is too lose.
Good luck
Mai
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Jan 30, 2008
SOURCE: bobbin tension
This is an issue of your upper thread tension, so take a look at this generic tension solution
If you are in a pickle with your bobbin case, check top tension and bobbin case are free of lint, reset the top tension to 4, and adjust the bobbin tension to suit......some more detail on how to do that, is here
Bargain Box
bargainbox
Hassy
  • 1388 Answers
  • Posted on Feb 24, 2008
SOURCE: how do I know which tension to adjust?
Are you sure that a stitch is being created each time, or is it missing some....
On a scrap, sew a zigzag to ensure that at least the stitches are being formed, if not, or missing some, look to timing.
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Anonymous
  • 9 Answers
  • Posted on Jan 05, 2009
SOURCE: lost my manual for my Brother CS-100-
Here is a site for the manual. Just click get manual, register for free on the site, then download it. It works great!
Anonymous
  • 6 Answers
  • Posted on Feb 21, 2009
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Mimito7
Kelley Buchanan
  • 130 Answers
  • Posted on Apr 19, 2009
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
How to adjust the bobbin tension on a Brother lx3817
I don't know your history with this machine so some of the following may seem basic beginner.
Be sure you have the right bobbin. This machine uses a larger bobbin than other Brothers. The manual also indicates some x3817 came with "quick set" bobbin feature for which lower threading is slightly different.
If you need a manual for reference, it's free download from Brother at;
https://support.brother.com/g/b/manuallist.aspx?c=us&lang=en&prod=hf_lx3817eus&flang=English&type3=626&type2=69
Extremely high top thread tension also may cause upper thread looping. You have tension at 3 which should be fine but there may be other issues affecting top tension.
Test top thread tension with needle up, presser foot down and tension at 3. Make a long slow steady pull of the top thread. The thread should advance smoothly through the needle eye with out snagging. Any sudden change in tension is suspect.
You can do a similar test of bottom thread. Bring bottom thread to top. With needle up, foot up, make a long slow steady pull of the bottom thread. Bobbin thread should advance from the hook case/bobbin smoothly with tension similar to the previous top thread test.
In general, the top and bottom tension should be near the same when top thread tension is set at 4. If you find an extreme difference in top/bottom thread tension at 3 then something is amiss. Re-thread per machine instruction.
I suspect top thread has looped around something or there's debris in the bobbin area.
If still a problem comment here with your findings and I or someone will assist further.
1helpful
Brother Sewing Machine CS-6000iNeed instruction:using double needle.Tension issues:Thread underneath is very loopy no matter what tension setting,top threads have missed stitches.
Try removing the top threads completely from the machine.
ALWAYS RAISE the presser foot== this allows the threads to seat fully in the tension disk. Thread one thread completely, then thread the other thread making sure to run it through the other tension disk (if your machine has divided tension disks).
Set the tension to the midway point.
Insert fabric, lower the presser foot, and retest. Adjust the top tension as needed,. If tunneling occurs between the two top threads and adjusting the top tension doesn't fix it, you may need to adjust the bobbin tension. However, before changing bobbin tension, I would try including tear-away or tissue paper with the fabric to add body to prevent the tunneling.
sewing with twin needle Google Search
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
I have a VX1250. I don't know how to regulate the tension.
There is two places to adjust thread tension: the top tension device controls the top thread tension and is usually a dial or knob with numbers on the front of the machine.
Then there is some form of tension device on the bobbin; in your case I believe the Brother has a removable bobbin case with a tension spring which holds the bobbin thread firmly: the tension spring can be adjusted with a screwdriver but once set, you shouldn't need to adjust this much, just alter the top tension slightly for different weights of fabric. So start by setting top tension dial to 4-5 and test stitch a seam. Use different coloured but the same type of thread top and bottom and take a look at the seam. You want to see a balanced even seam.
Here is a link to a great info site for this:
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If the bobbin thread is too loose, then you probably will need to finess the tension spring on the bobbin case and adjust this slightly. The best way to set the tension on the bobbin case is as follows. Load the bobbin into the bobbin case and pull the thread tail into the tension spring, then suspend the bobbin by holding the thread tail up in the air (the dangle test). You want it to be just tight enough to hold its own weight, but still able to release thread when you pull gently downwards on the bobbin case. If it isn't doing this then take your little screw driver and adjust the screw on the leaf tension spring by ONE QUARTER TURN ONLY. Lefty looser, Righter Tighter. Then test again, and adjust again until its right.
Now test stitch again and finess your top tension to get the seam even. Remember to change the needle for each new sewing project too; this will impact tension also.
Sewing machine stitches upside down!
Sounds like you may need to have the tensions adjusted. If the bobbin thread is showing on top, the bobbin tension may be too loose. If the top thread shows underneath, the top tension is probably too loose. Since you are having both problems, perhaps a technician should take a look at it.
2answers
Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
1helpful
3answers
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
