Likely in the serial number. Google fedders serial number diagnostics
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
SOURCE: need a fan motor for fedders model A6Y18F7B 18000
Easiest thing to do is pull the motor out and take it to Grainger. They can probably match it with a Dayton brand. No HVAC place will sell you a motor. They are all wholesale, and not to the public. You really don't have a whole lot of options here.
Good Luck
SOURCE: wiring for a
L1 to board to one side of thermostat.
Other side of thermostat to one side of compressor overload.
Other side of overload to (C) terminal on compressor.
Should work now.
SOURCE: what is the air exchanger (open or closed) switch for?
The air exchanger is there to give you the option of adding fresh outdoor air [open] or recirculate the air in the room [closed].
SOURCE: fedders A3X06F2G window air conditioner fan does not spin
Fan motor is stuck or defective it might need replacement. Check for broken fan blades or obstruction.
