SOURCE: Codes for my system
i was having problems setting up Magnavox DVD/VCR player. none of the codes were working. i thought maybe try the Phillips code in the quick set up since the company has been known to be Philips Magnavox and success!
SOURCE: Need to remove base from Venturer 26'' LCD TV
look on the tv above where the base slides into the tv and you will see screws. unscrew those screws and lift the tv off of the base.
please mark my answer as a fixya!
SOURCE: Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge. Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
SOURCE: Looking for replacement remote for Venturer 22
Try here: http://remotes.com/remotes/servlet/rs?a=Search&mode=brand&v=1&brand=Venturer&uuid=A12605685976201
Testimonial: "WOW - Answered in just a few minutes of posting. Thank you Cindy."
SOURCE: Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
http://www.espares.co.uk/search/remote-controls/p/1090?utm_campaign=06-2011+unlimited+credit+1st&utm_medium=email&utm_source=emails ........ search for models of all types
