Question about Rowenta Perfect Iron
THIRD leaking Rowenta
I am on my third leaking Rowenta, and this will be my last! Sent the second one for a warrnaty repair, and they replaced it...then it started leaking. I was told by the repair specialist to only use spring water, explained that I have never used anything but bottled spring water. Then splurged and got the Professional grade Rownta without auto shut off- I sew as a profession....quite an investment- over $100...BUT, here we go again...I will NEVER again purchase a Rowenta. Am not sure what I will get, but am sure of what I won't get again
  • 67 Answers
Try buying a cheap one from wallmart or some similar store. They are not too dear so you can use them until they fail and then buy another cheap one.
Posted on Aug 04, 2009
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
Rowenta microsteam 400
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
Jul 29, 2014 | Rowenta DW-8090 Pro Master SEWERS Iron...
How to fix rowenta dz2061 leaking
Repair or replace it.... Super unsafe to use if it's leaking.
Jul 01, 2014 | Rowenta Irons
Will not turn on
There is some misconduct wire, loose or disconnected. Have it serviced, if possible replace the cable :)
Apr 04, 2010 | Rowenta Power Duo Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
I purchased a rowenta professional DX8600 April 2009, just recently tried using it (because my old cheaper iron was still working), but the new iron leaks while being used and automatically shuts off while...
The retailer is talking nonsense. Your contract is with them and under the sale of goods act if something breaksdown in the first six months the onus is on the retailer as it is deemed faulty, they should either offer to repair or replace last resort money back. Go back to them and tell them if they don't then you will contact trading standards as you have rights under the sale of goods act. If they don't listen call trading standards and they will sort it out for you. It won't cost you anything.
Aug 08, 2009 | Rowenta Professional DX8900 Iron
Iron will not go on until you wiggle cord &ball
Rowenta DZ 9050 steam iron must be sent to Rowentas repair service in your area.
Local Fix shops will not work on them.
They have parts only.
Feb 19, 2009 | Rowenta Irons
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Water Leaking
The seal between the top and the bottom plate has lost it's integrity. First try tightning the 2 screws on the underside of the iron. If that doesn't fix the problem, then you will need to take the iron apart and fix the seal. That will require you to remove those 2 screws and also a third screw that is up by the toe of the iron underneath the sprayer. You will then need to slowly pull the 2 pieces apart becasue the seal is made of a sticky rubber substance. Once you get it apart, you can then distribute the seal material to cover the bad area. Then just put it back together!
Dec 15, 2007 | Rowenta DZ1700 Iron
Rowenta Perfect Iron Logo
703 people viewed this question
Top Rowenta Irons Experts
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
