Question about Toshiba Satellite A105 Notebook
Toshiba Satellite P105 S6147 screen won't illuminate when on?
Laptop has power to it but the screen doesn't illuminate.
  • Chris Hingee
    Chris Hingee May 11, 2010
    Does the laptop appear to boot up? Is the hard disk spinning and the hard disk LED flash? Can you see a dim image when you view the LCD screen at a sharp angle?
  • 202 Answers
First try the fn+lcd/crt and see if it toggles on.if not then try hooking it to an external monitor. if you get the pic on the external monitor then you have a backlight or inverter problem.
Posted on Jul 27, 2009
Toshiba Satellite P105-S9722 white screen on stat up
Don't assume. Diagnose.
Problem could be graphics chipset, Video Cable, screen Inverter, or LCD screen.
Graphics chipset:
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
(Back of laptop - Blue)
Example of a VGA Cable, and a VGA connector, (Port on laptop),
http://en.wikipedia.org/wiki/VGA_connector
If you have a CRT type of monitor (Looks like a small TV), you can use it, or a flat LCD screen monitor with a VGA cable.
The Toshiba Satellite P105-S9722 Notebook PC, also has a DVI connector on the back of the laptop. (Next to the blue VGA port)
You can connect a flat LCD screen monitor with a DVI cable.
Example of a DVI Cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default the display should be on the external monitor.
If not;
Press, and hold down on the Fn key, (Bottom left), and tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
You will see a list. It 'hot cycles' through the list, until you come to the external monitor device you are using.
http://shop.mcccomputers.com/network-modem-cards/6037-toshiba-satellite-p100-p105-p105-s6104-p105-s9722-video-board-256mb-ts15082.html
External monitor display shows no white screen?
Your graphics chipset is good.
Go on with the diagnoses.
Problem is with the Video Cable, or in the Display Assembly.
(Screen Inverter or LCD screen)
Video Cable:
The Video Cable attaches to the motherboard under the Switch Cover, and about at the F2 and F3 keys.
It then routes under the left Hinge, and up into the Display Assembly.
From there it connects to the screen Inverter, and back of LCD screen,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/big/toshiba-satellite-p105-11.jpg
From;
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Due to normal opening, and closing of the laptop, the Video Cable may become pinched, and pulled on.
This can lead to a simple loose connection of the Video Cable TO the motherboard, or TO the back of the LCD screen.
(The screen Inverter connection should also be checked)
Visual inspection will NOT do. You need to physically see if you can plug the motherboard connection, and LCD screen connection in.
It could be just loose enough you won't be able to see it, but will affect the display.
Sheath of Video Cable needs to be visually inspected for signs of damage. Signs of damage to the sheath, may also mean damage to the tiny wires inside the sheath of the Video Cable.
(Stretched/Broken)
Assurance that the Video Cable is not the problem, means checking out, or have checked out, with a multimeter set to OHM's, to run a continuity check of all the wires.
('Mom and Pop' computer store. See if they will check it)
Or simply replace the Video Cable. (After you fire up the laptop, and see if loose connections was, or was not the problem)
http://www.batterysupport.com/toshiba-satellite-p105-s9722-cable-p-377633.html
(Left side connects to LCD screen. Right/Top connector goes to motherboard. Right/Bottom connector goes to screen Inverter)
Video Cable checks out OK?
Go on to screen Inverter.
http://www.ebay.com/itm/TOSHIBA-Satellite-P105-S9722-laptop-lcd-Screen-Inverter-/250759700669
The plastic thin frame in front of the LCD screen, is the Display Bezel.
The screen Inverter is behind the Display Bezel, and mounted at a location towards the bottom of the LCD screen frame.
A screen Inverter is tested with a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
It is for this reason that those who do not have access to a sensitive multimeter, usually just replace the screen Inverter.
(Also low cost, and ease of access to replace)
Screen Inverter checks out OK?
Problem is the LCD screen,
http://www.amazon.com/SATELLITE-P105-S6084-P105-S9722-P200-140-REPLACEMENT/dp/B007QEEYGE
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Bet it's the video cable, or screen Inverter, that is the problem ]
[ Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Toshiba Satellite P105-S9722 Notebook PC, uses One CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
General example,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A CCFL contains -> Mercury, just like Fluorescent lighting used in homes, and businesses.
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
90 Percent of the Time the fault is a bad screen Inverter.
Primer over.
Oct 16, 2012 | Toshiba Satellite P105-S9722 Notebook
Forgot password toshiba satellite p105-s6147 how can I login?
If you do not have a reset disk, you can use Windows Password Reset ( http://www.windowspasswordreset.net ) to create one.
If you have already have one, so just do as below:
Here are the steps to use the disk for your password recovery.
Step 1: If you enter the wrong password when you attempt to log on, Windows will display a message that the password is incorrect. Click "OK" to close the message box.
Step 2: Click "Reset Windows Password", and then insert Windows password reset disk (or other removable media).
Step 3: Follow the steps in the "Password Reset Wizard" to create a new password.
Step 4: Log on with the new password.
Hope you can reset windows password soon
Jul 11, 2012 | Toshiba Satellite P105-S6147 Notebook
My Toshiba Satellite P105-S6147 PC Notebook - has two problems - The screen has thin colored lines running vertically in about 4 places on the monitor and a 3 inch wide "ghost" band on the right...
Sounds like your display panel needs to be replaced.As far as your speakers they sound to have gone bad if it plays sound externally but not on the onboard ones.
Feb 04, 2011 | Toshiba Satellite P105-S6147 Notebook
I have a line going down the middle of my toshiba laptop, any suggestions??
Usually indicates first signs of LCD going out. Must replace monitor or replace parts inside the lcd screen.. Both are costly and the best way is to replace the screen but depending on the age of the laptop you are better off investing in new low end model. Most laptop screens go from 150-250 and newer lower end laptop goes for 400 so tough call.
May 25, 2009 | Toshiba Satellite P105-S6147 Notebook
I have a Toshiba satellite p105-s6147 when i press the power button the blue light comes on but nothing happens even when i have it pluged in the wall with and without the battery.
Majority of the time with the P105 it's the motherboard that is at fault.
You can try reseatting the memory modules to see if that makes a difference but other than that there's not much you can do but replace the board or send it into Toshiba for repair.
Mar 09, 2009 | Toshiba Satellite P105-S6147 Notebook
Monitor...
you can connect laptop and tv with the help of s-video cable
and also after u make connection successful, another cable is needed
for audio to convert sound from laptop
Jul 27, 2008 | Toshiba Satellite P105-S6104 Notebook
Dark screen?
either it is set to use an external monitor, or the backlight or inverter is bad
Jan 11, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
331 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
