Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Ok I just bought a used fosgate amp belive its a T10001b could be wrong its big has fan 3 led lights and some pioneer premier 10 flat subs think there 4ohm. I bought a brand new amp install kit 6gauge lighting audio. Iv inatalled many of systems in friends cars and also mine so I belive I know wat I'm doing most of the time. The problem is I'm only gettin sound from the left sub??? Iv tried bridghing it both was with L and R subs still only 1 side works L. Also changed rcas from left to right on amp and on deck???. Belive rcas are good becuz iv ran the left sub off of the left and right rcas but when hookin them to the right input to amp on both rcas nothing. My buddy says it has to be brigded becuz speakers are to big iv tried that tried every thing. I think he fried the right side befor becuz his power cable where the fuse goes was melted ??? But the amp fuse is good.
  • 733 Answers
If you are willing. open up the amp and inspect the connections to the rca's on the side that is not working. check the solder connection by gently moving the rca input plug, see if you can tell if the solder is being pulled up. Re-solder the leads(MAKE SURE YOU DON"T SHORT THE LEADS TO OTHER PARTS OR CONNECTIONS OF THE AMP). If after you do that and it still does'nt work, check the transistors for damage. They're the ones that usually are against the amp housing, for heat dissipation purposes. If no visual seen, check them with an ohm meter and do a continuity test to see if one or more of the transistors are not shorted. You'll hear an audible when you check the leads. To help you out, test the side of the amp with the known good transistors and cross refference with the ones on the bad side. i know it's alot, but a little troubleshooting ain't so bad if it saves u money...
Posted on Sep 05, 2009
    New Friend:
  • 23 Answers
Eyp, most of the time speaker connections blow and fuses wont stop that from happening. They are there to stop the mainboard from frying and not working at all. try running rca splitters to the operational side of the amp. run the sub on 1 channel. you will start hearing a difference but both sides will work. if not, run the splitters from the head unit and bridging it. these are the cheapest solution i could provide
Posted on Jul 27, 2009
Pioneer box
Thanks for using fixya!
I have had the same problem that you are having right now. I basically don't know how to start making my own sub box. Well, I chose the Bass-reflex type Box. This the best. Check this link out for a detailed overview of sub box making. http://www.hardwareanalysis.com/content/article/1789/build-your-own-10-inch-subwoofer/
Have a great day.
- HotRatchet
Jul 26, 2009 | Pioneer TS-W307D4 Car Subwoofer
I have a rockford fosgate punch 150 and it will power a small 5 1/4" speaker, but doesn't seem to push my 15" subwoofer. I am reading 4ohms across the sub so I'm assuming that it is fine and that there is...
amp is way too small to power a 15 inch sub. But you should get some sound out of it, not silence. You can use a 9 volt battery to test your sub, if the sub pops when the 9 volt is placed across it's terminals then it's ok. If it does not pop then your sub may be bad, or the coil may be frozen. (It can still read 4 ohms if frozen). If your amp powers smaller speakers fine, you know it's not the amp. If the sub tests ok, then verify your connecting it properly to the amp's correct bridging terminals.
Jun 12, 2009 | Rockford Fosgate Punch 150S Car Audio...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
How to buy the best subwoofer
There are several factors to what sounds good in a subwoofer. Your head unit, amp, enclosure size and enclosure type as well as where its placed. I tend to think that fosgates are superior to a lot of speakers but orion and JL are making some pretty impressive speakers too. Check the speakers need for airspace and make sure you can accomodate it. If you can, and the resonant frequency is more to your liking then move up to fosgates. Personally, I think the difference MIGHT be minimal assuming you are using the same inclosure, amp and head unit. Good Luck!
Dec 27, 2008 | Rockford Fosgate Pl1 210 Stage 1 Dual 10"...
How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Dec 03, 2008 | Rockford Fosgate 25 To LIFE Punch 150...
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Amps
It comes down to Amperage and RMS, your best bet is to go in and talk to a salesman at a stereo shop. That way he can decide on what sort of power you want and how you wanna use the subs. But 1000amp AMP is probably a good start 4 channel of course. Alpine or SOny make some kick a$$ AMPS
Feb 17, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Head unit
If the display goes out then it is possible the flex cable is broken. Return it to Rockford for repairs.
Jun 19, 2007 | Rockford Fosgate RAV DVD1 Car DVD Player
Pioneer amp and sub problems
That's a 4-channel amp, not a 2-channel, which makes me wonder exactly how you have it hooked up to your sub. Is the LED light on the amp coming on? How many subs do you have hooked up to it, and how is it wired?
Mar 04, 2007 | Pioneer GM-6200F Car Audio Amplifier
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
127 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
