2004 dodge ram 2500.a/ blows cold air out of 2 left dash vents but blows hot air out of right side vents sometimes
    Champion:
  • 233 Answers
Blower blend door is either sticking or not actuating, (located usually above the feet of the passenger) trace the hoses from the firewall to the manifold see if all are attached and not cracked.
Posted on Jul 27, 2009
2004 2500 6.0 Silverado ac blows HOT on alternate sides of vehicle while in Auto A/C mode.
Douglass, Your A/C may have lost it's programming, blend door actuator could be faulty or A/C could be low on refrigerant. You may have to take in and have a good Tech. diagnose and estimate repair.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dual climate controls drivers side hot passengers side cold have 2004...
hot on driver side
Drivers side vents will blow hot air while is turned on but passenger side...
Jul 26, 2016 | 2004 Chevrolet Silverado 2500HD
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
Sep 12, 2012 | 2009 Chevrolet Silverado 1500
I have a 2004 hemi dodge ram 1500. The air on the passenger side blows hot air. What is this, and what should I do to fix it?
Does it do this even if A/C or cold air is selected? If so, the switch that controls the vents may be loose or broken inside so it's not opening the vent for cool or cold air. Check to see if it does this with A/C on as well. If so, consider pulling the vent assembly under the dash and finding the error.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 22, 2010 | 2004 Dodge Ram
Cold air only on left two dash vents,hot air on the right side.
Go to pdftown.com and download the service manual for free. I think the 2005 one is corrupt tho......so get the 03 or the 06. Otherwise go on the Dodge or the Cummins forums and they have all kinds of help and advice and often photo walk-thru's of all kinds of repairs.
Jun 01, 2010 | 2004 Dodge Ram
2003 Dodge Ram 1500 quad cab. While replacing a
it may be the switch itself they do go bad.Otherwise he could have pinched a hose or left one off. But it sounds like he is trying to help.
Feb 11, 2010 | 2004 Dodge Ram 2500
I have the same problem. Solve. The passenger side vents on my Dodge ram 2004 deisel blows warm and the driver's side vents blows cold.
Sounds like you have a bad blend door actuator, or a bad control unit. Need to have it checked to find out which it is.
Jul 31, 2009 | 2004 Dodge Ram 2500
Looking for a Air Conditioning Wiring Schematic For A 2004 Dodge
There is a flap that directs the air flow. The flap is controlled by a vacuum operated actuator inside the venting.
Jul 02, 2009 | Heating & Cooling
Air is going from hot to cold
the orfice has a filter and my be plugged up
May 21, 2009 | 1999 Dodge Ram 2500 4WD
Heating & Cooling Logo
172 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
