Question about Nursery Pro Inc Ultraklean Filter/Light
Is there a separate UV unit that can be installed in the UltraKleen 1000 Gal filter? I purchased a unit without the UV portion and wish to upgrade it. It appears that the UV unit would simply fir into the cap of the filter unit. Duff Kerr duff.kerr@att.net 303-871-0449
  • 3,037 Answers
Unfortunately there is not a separate unit that they sell. Their complete product catalog can be found at the following website link
http://www.aquascapeinc.com/upload/09_Retail_Catalog_FINAL_LR.pdf
I would try contacting AquaScape or a dealer near you if they would consider upgrading you to a unit with the UV light or selling just the part with the UV light. I'm sorry that I can't give you better news. Let me know how this turns out.
Benjamin
Posted on Jul 27, 2009
Can weco polaris uva-1c system be installed under the sink by itself?
UV water disinfection systems can be installed downstream of your already installed kitchen reverse osmosis water filter system or just by itself. US EPA states that "UV treatment is an effective process for inactivating many microbial pathogens in water with potential to serve as stand-alone treatment or in combination with other disinfectants."
Easy way is to cut the faucet tubing (blue tube) in middle and connect the UV. Wall mounts should be included inside the UV package.
However, if you already have the tiny ro system, check the diagram below and install the uv between the auto shut-off valve and the 4th stage filter (polishing filter).
To nicely fit this UV into the RO system, you'll also need two 2-1/2" X 2" double filter clips. Tubing this way should allow more contact time for water and uv rays since the flow rate from the membrane is very slow.
https://cfpub.epa.gov/si/si_public_record_report.cfm?dirEntryId=309164
Apr 12, 2018 | Option Computers & Internet
I have no hot water, how do I change the filter in a Bock Water Heater 32E 32 gal oil-fired hot water heater ?
Unfortunately, looking at the manual for the water heater, the filter is a separate item. And the recommended Delavan line filter page just shows a picture and part numbers of the item, not how to remove it.
I suspect it works in such a way that you hold the end nut portion and turn the large nut portion with open end wrenches. You will need the internal filter replacement and possibly new seals, probably in a kit.
Line Filter
You'll want to turn off the power to the oil pump so you don't make a large mess.
Jul 20, 2016 | Water Water Heaters
Honeywell UC100E 1006 "snap-lamp" unable to unplug the lamp from the socket
Sorry that i cannot help you as this was some how posted in the TV area which is not your fault.
Dec 06, 2012 | Televison & Video
Will a Vivitar 58 mm UV filter attach to a Nikon d3100 18-55mm lens?
Not directly. The 18-55mm takes 52mm filters. However, you could purchase a 52-58 step-up ring to allow you to adapt the filter to the lens for significantly less money than a 52mm UV filter. One such adapter is http://www.adorama.com/IRXRA5852.html
Aug 03, 2011 | Vivitar Cameras
I bought a Rocketfish 55mm uv filter and tried to install in on my 18-55mm lens. I thought it would be easy but I think it's a wrong fit. I need help installing it.
The 55mm uv filter refers to the diameter - 55mm. This is unrelated to the focal length of your lens 18 - 55mm, which could be any diameter. You need to note the required filter size of your lens and purchase the appropriate size.
Jan 24, 2011 | Cameras
In the past when film was still king and I was using it I had always used a UV or a Polarized lens cover. Now in the DSLR world I've been told that I should not use a non rated DSLR lens cover. Is there...
Without specific reference to the D90, the following applies to almost all dSLR's: Skylight filters (UV) are fine, but avoid using auto white balance. Polarisers can prevent the autofocus system from working, but the more expensive circular polarisers are usually OK although don't produce quite the same effect as linear polarisers.
Oct 08, 2010 | Nikon DSLR D90 Digital Camera
Currently have a filter pump that hangs on side of pool. want to purchase a larger (1500gph)pump. these all sit on ground
I recommend upgrading to sand filter system. You can get a good one from Amazon seller for $305.00 delivered. Pump made by Waterway. (we are very pleased with ours). The intex pumps just aren't sufficient for the pools they come supplied with IMO. It's a little more pricey than upgrading an Intex pump, but so worth it.
I hope this has helped. Good luck!
Jul 09, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Nursery Pro Inc Ultraklean Filter/Light Logo
Top Nursery Pro Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Nursery Pro Garden Expert? Answer questions, earn points and help others
