Question about Sony Playstation 3 (PS3) Console
More PS3 Hard Drive Problems
I bought a new 320GB 2.5-inch 5400 RPM Hard Drive for my ps3. When I turn it on it says it will format then at 7% it turns of and the light blinks red until i touch it. When I turn it back on it says it is corrupted and will reformat, but when i hit ok the same thing happens again. Whats wrong, plz tell me how to fix it.
Probably you have got problems with a sector of your Hard Disk .
try formatting it via a PC platform, then use windows to verify possible errors (if any, it will try to fix).
else, try using a new hard disk and if it's new, turn it back to the store you bought it ,
Posted on Jul 27, 2009
I bought a new 500gb sata hdd to upgrade my ps3s old 40gb one and after formatting it my ps3 runs slow meaning I cant play any games, any ideas why this is?
Make sure the new hdd runs at least 5400 RPM. A 7200 RPM drive is a little better (or a Solid State Drive if money is of no concern).
Sep 12, 2013 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console My PS3 hard disk is corrupted, It say to restore i put restore and nothing had been restored Bid
Corrupted hard disk? Lets see....
You could attempt to boot up the PS3 in safe mode and restore the file system (should delete any corrupted data). Describing how to start up your PS3 in safe mode would just be confusing, so instead here's a link to the official page on the PS3 Safe Mode feature.
Follow the instructions, and then I'd say try options 3 (Restore File System). If that doesn't work, try 4 or 5 (Rebuild Database or Restore PS3 System).
If that fails, you could just replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
If somehow the new hard drive doesn't fix it, or you don't feel like buying a new hard drive, you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe).
If you request the repair service, they send you a box, you put the PS3 in it and ship it back to them. A month or 2 later they send you a fixed/different PS3. Simple, but takes forever to get a working PS3 back which is why I suggest you try a new hard drive first.
Anyways, hope you get it working soon!
Mar 22, 2011 | Sony Playstation 3 (PS3) Console
My Verbatin 320gb hard drive works perfectly fine with my macbook pro.. However, if i plug it in to my windows vista pc or my ps3... it just doesnt show up. ODD.
do you hear it connect through the speakers when you connect via USB? If you do then click start > right click on computer and click manage. click on disk management and see if you can see the 250gb hard drive. if you can, then right click the drive and click change drive letter, if nothing is in the box indicating it has a drive letter assigned then click on add and choose a letter, if you now see the drive when you open explorer but cant access it then the reason it isnt showing in windows is probably because you have formatted it as a mac filing system.
Please vote for me if you find this info useful
Mar 11, 2011 | Verbatim SmartDisk Firelite Portable USB...
Firelite 49 GB is no longer recognized by my PS3
hi,
it's cause when you formatted the disk, you choose to use ntfs file system and ps3 can only read fat32.
when you format a hard disk or eaven a usb drive you can choose wich fort to use.
there are different tipe, most common are fat, fat32, and ntfs.
most actula operating system uses ntfs, but fat32 is still he more compatible.
reformat your hard drive as follow:
got to "my computer" on your desktop, right click on your hard drive and choose format.
a window should pop up.
under file system chose fat32.
leave untouched all other fields.
you could perform a quick format, but i suggest a full complete format, so leave all untouched and wait till end.
now it should work.
regards,
Paolo.
Jun 04, 2010 | Verbatim SmartDisk Firelite Portable USB...
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Used laptop hard drive in a playstation 3
Forget trying to have both things on the one drive, it's a non-starter. I believe the PS3 formats it itself, and it's not exactly the place to be putting your system files at risk. Hard drives are CHEAP! Get another one. It should match the PS3's original HDD specifications for current (Amps) used and RPM (5400 I believe). Otherwise you're likely to have problems with heat and reliability.
Aug 30, 2009 | Sony Playstation 3 (PS3) Console
New hard drive problem
There sounds like there is something wrong with the drive. If it is a SATA notebook hard drive with the same RPM (5400), there shouldn't be any issues at all.
Double check this by reformatting the old one you replaced it with (as long as you have your data backed up). If that reformat goes smoothly, get your new drive replaced.
Jul 26, 2009 | Sony Computers & Internet
Ps3 screen wont come up
I think i've found two solutions with one being the easiest, hassle-free and no-cost solution and the other simply alternative DIY solution.
1) I phoned Sony Customer Support and the person i spoke to was really polite and organised a 'striaight-swap' console-for-console. They are sending a courier to my house with a new ps3 with the 40gb hard drive, similar to that in my 'damaged' console.
They said dont give them any cables, games or even the hard drive which you can take out and keep- they are quite literally swapping my old machine for a new one, which comes with a pre-fitted hdd.
I phoned them on Monday and they said it would arrive sometime on Thursday.
I strongly suggest anyone with this kind of problem and minimal, otherwise no experince of replacing hard-drive's themselves to do the same - after all, no extra costs are required, only a few days without your console.
2) I'm not entirely sure about people outside of the UK, but if you go to www.play.com, you will find a cheap and affordable-for-what-it's-worth hard drive that you can fit in and as gamerfixer07 has stated, 9 times out of 10, it will work.
The HDD specs are:
-Western Digital (brand)
-320GB
-2.5" (of course)
-5400 rpm (don't ever get 7200 rpm unless you wanna burn your ps3)
-good seek speed
-£49.99 (Hey! If your currency is the Euro then its cool cos it's almost £1 = 1 EURO).
I hope this helps.
Please leave some feedback if everything is ok. Thanks!
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 Main Menu doesnt load.
I think i've found two solutions with one being the easiest, hassle-free and no-cost solution and the other simply alternative DI solution.
1) I phoned Sony Customer Support andthe person i spoke to was really polite and organised a'striaight-swap' console-for-console. They are sending a courier to myhouse with a new ps3 with the 40gb hard drive, similar to that in my'damaged' console.
They said dont give them any cables, games or even the hard drive which you can take out and keep-they are quite literally swapping my old machine for a new one, which comes with apre-fitted hdd.
I strongly suggest anyone with this kind of problem and minimal, otherwise no experince of replacing hard-drive's themselves to do the same -after all, no extra costs are required, only a few days without yourconsole.
The HDD specs are:
-320GB
-2.5" (of course)
-good seek speed
-£49.99 (Hey! The Pound is getting weak because of our economy and its almost £1 = 1 EURO).
I've ordered mine because 40GB is not enough for HD films/TV shows, despite Sony giving me one anyway which is nice of them.
I hope this helps.
Apr 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
220 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
