Question about Kitchen Ranges
Hello- I have a GE oven model number: JGBP85CEB3CC. I was using it today with no problem. then an 2 hours later. I went to turn it on and it heated up to 109 then just stopped and wouldn't heat any more. I turned it off, restarted it, nothing- just stuck at 100. The broiler won't work. Burners DO work :). I need to fix this myself- I can't pay for labor right now. I need to be able to bake. Please help. Thanks.
  • 1 more comment
  • macharsky Jul 27, 2009
    Thanks! I was actually able to turn on the Broiler- do you still think it is the sensor?
    Do I need to do the OHM testing (was that the right name??)? I don't have that tool.
    I was able to get my broiler to work- do you think it is still the sensor?
    Must i do the OHM (?) testing?
    Thanks!
    THANK SO MUCH~
  • 15,935 Answers
The thermostat/sensor is most likely the culprit.
if you remove the back panel of your range - there should be a service manual that will give you the location and testing procedure.
CLICK HERE to see the available expanded diagrams.
It is part number 43 on THIS DIAGRAM
CLICK HERE for success stories installing this part.
Order it HERE
Thanks for using FixYa - please accept this answer to remove it from the work queue.
:D
Posted on Jul 27, 2009
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I cleaned my GE model JBP66D range that is only a year old and 6 hours later I went to turn the oven on and heard a click and then the power went off. It tripped the breaker and when my husband went to...
Best thing you can do is call GE at 1-800-626-2000 and tell them what happened. Some of these ranges were covered by a recall for that very reason, but even if it isn't, complain loud enough, they;ll fix it.
Oct 24, 2017 | GE JBP66 Electric Kitchen Range
Oven does not heat but broiler does.
hello mam please visit the manufacturers website there you can find it.
Oct 08, 2009 | Kitchen Ranges
GE true temp oven f2
This happens every time I clean my oven. It overheats, shows the f2 light and BEEPS loudly. The only way to stop it is to turn the oven off at the breaker box, wait until it cools (usually 2-3 hours), flip the breaker back on and start the process all over again until the unit is clean. If it's not to dirty, sometimes it's easier to juat use Easy Off.
hope it helped
Jan 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spacemaker microwave won't heat food
hello kmwnky,
You say that Everything went out at first ( which I assume means that all functions went dead) and then functions started to operate again later... if that is correct and you smelled something burning.. you may have a thermal fuse that failed, filament transformer that failed, magnetron tube that failed or a highvoltage capacitor that failed.. None of these components are something the untrained person should attempt to trouble shoot or replace since there are dangerous energies stored inside the electronics compartment even after power is removed.. Your Micro is > 8 years old and it's probably not worth the cost of repairing at this point. You'd be better served replacing it.. The cost to repair would exceed the cost to replace.. ( I feel like the grim reaper here..sorry..)
Regards,
Rick
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Oct 02, 2008 | Kitchen Ranges
Self-Cleaning Whirlpool Oven
Hello, I am cleaning my oven today. I went to the whirlpool.com website and clicked on customer support and typed in my model number which is located on the front inside panel of my oven. They will provide you the manual with the self cleaning instructions. I hope this helps.
Jul 04, 2008 | Ovens
Self cleaning oven instructions
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
Jan 05, 2008 | GE JKS05 Electric Single Oven
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
19 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
