Question about Briel CG5B Electric Burr Grinder
Need new reservoir
Need new ground coffee reservoir
  • 57 Answers
You can contact Briel direct they will supply spares but only from Portugal (I am in UK no one held spares) Email customer service Remember post costs could be high so consider replacing the Briel locally as it is obsolete and although a good entry level grinder, far better ones can be obtained and after all grind consistency is everything. If it is just the return spring see my FixYa. Address below Anabela Maia de SousaAfter Sales ServicesBriel - Industria de Electrodomesticos, S.A.Rua Sidonio Pais, 390 - Lugar do Rio4475-498 Nogueira da Maia - Portugalanabela@briel.ptwww.briel.ptTel: +351 22 961 9430Fax: +351 22 961 9435
Posted on Nov 24, 2009
  • Peter Bradley Nov 24, 2009
    If it is a broken return spring you can easily fix it. I diassembled the doser housing (three screws in the base) and found the return spring had fractured. I did not have any spring steel (such as a piece of clock spring) so I found it possible to cut a piece out of an old feeler gauge (38 thou) using tinsnips. I cut to the correct length and glued into the plastic housing as originally
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
The sensor inside the water container has either mineral build-up (scale) or a bit of coffee grounds stuck to it.
  1. Run a cycle with a retail coffee maker "cleaner solution" to clean the water reservoir, or let vinegar soak inside 5+ hrs.
  2. In both cases, turn unit upside down and power wash reservoir 2X to dislodge deposits that have loosened during the soak.
  3. Make sure to run a few cycles of plain water thru coffee maker before making the next batch of coffee.
Dec 06, 2015 | Saeco ODEA Coffee Makers & Espresso...
Can I dump water out of reservoir and refill
To empty the reservoir, you need to turn the whole unit upside down while holding it over a sink or outside on the ground that can get wet. Be sure to turn it on and wait for the water to heat up before brewing a pot of coffee.
Nov 13, 2015 | Bunn 10 Cup Home Coffee Brewer
Ground coffee does not get wet
try to fill the reservoir with the water to the top, when the water starts "brewing" the water is transfer from this reservoir to the basket where there is loose coffee placed over the paper bag that will filter the coffee to the jar.
Check if anything is blocking the canal, that is transferring the water from the reservoir to the basket.
Mar 01, 2015 | Cuisinart DGB-550BK Grind-and-Brew 12-Cup...
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Recalls on keurig
Empty the reservoir of any water. Fill it back up with white vinegar. Get a paper clip and poke it up in to the needle that the water comes out of on the top of the lid. Run the vinegar through the machine until the reservoir is empty. You can even let the vinegar sit in the coffee maker for 10-15 minutes. Refill reservoir with purified water and run the maker until all the water is dispensed and the reservoir is empty. There should be no more vinegar smell. Never use tap water. Do this every two months. Note: if the area where the K-Cup sits gets dirty with grounds, put a large bowl under it and then pour a glass of water over the whole area to clean. Also, on occasion just run a cup of water through the machine (with no coffee) just to make sure that there are no grounds caught in the needle. Done!
Feb 19, 2012 | Keurig B60 Coffee Maker
I can't get a full cup of coffee. I've descaled my machine and it still doesn't work properly. Any other suggestions?
If your brewer is not brewing the full amount selected, it may be caused by the following:
  • The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
Jan 14, 2011 | Keurig B60 Coffee Maker
I can hearing brewing noise, but no water filling the carafe
IF UNIT IT`S MORE THAN 4-5YRS BUY A NEW MODEL, U SAVE SOME MONEY FOR THE NEXT 5YRS
Aug 19, 2009 | Coffee Makers & Espresso Machines
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
Weak Coffee
I don't have any first-hand experience with this brand. However, it sounds like the coffee grounds are being partially bypassed by the hot water.
One clue that will help diagnose this is: does the carafe fill up to the amount of water that was in the reservoir? If not, that suggests not all the water is being cycled through.
See if the reservoir is completely empty at the end of the brew cycle. Look for any coffee-colored water in the reservoir at the end of the cycle. That would indicate, to me, a defective feed valve in the water path.
Dec 28, 2007 | Keurig B50 Coffee Maker
Briel CG5B Electric Burr Grinder Logo
149 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
