Question about Akai PT5492S 54" Rear Projection Television
Red/Orange horizontal lines
Why is there colorful orange and yellow horizontal lines going across my tv
  • 476 Answers
It could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Posted on Jul 27, 2009
I need to know what the various colored wires connect to since I needed to remove the old amp and install an after market stereo.
Check the speakers connection and that should give you at least 8 of the colors. The ones left then are going to be ground and power and display power. You can figure those out with a meter.
Aug 24, 2015 | 1994 Volvo 940
Tip
How to measure Voltage in Transforme for Fitness Treadmill
Transformer Test Procedure:1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow
Transformer Test Results :1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and power to the drive board. 2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
Transformer Wire Colors Normal Voltage Value:
Red and Red 110 VAC.
Black and Black 11-13 VAC
White and White 11-13 VAC
Orange and Orange 27-29 VAC
Yellow and Yellow 10-12 VAC
on Oct 26, 2011 | Exercise & Fitness
Tip
How to measure Voltage in Transformer for Fitness Treadmill
Transformer Test Procedure 1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow.
Transformer Test Results:1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and powerto the drive board.2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
ValueRed and Red 110 VAC
.png
ERNESTO CUADRA
MANAGUA, NICARAGUA. C.A.
Hook up to the Wii
Alright so first of all, you should have gotten a cord with a big, grey power brick attached to it. Plug the end in that goes in a outlet, and the other end should hook up to one of the outlets on your Wii console. Then, there should be a cord with three branches. They should be colored red, orange/yellow, and white. On the back/front or on the cable box for your TV there should be plug-ins that are colored either red, white, green, blue, or orange/yellow. The specifications should be written under the outlets (visual, audio, etc...). Plug the white and red part of the cord in to the "audio" outlet (on your tv). The other cord (yellow/orange) should plug in to the outlet that is labeled "video" or "visual" or "screen" or something along the lines of that. The next step is pretty simple. Your Wii (should have) came with a sensor bar. It is thin, long, and black and has a very long, very thin cord attached to it. Plug one side of the cord into your Wii console, and the actual sensor bar goes on top of your TV. There are small, sticky rectangles that help with the sensor bar sticking to your TV. After you've done all that, your Wii is ready to go! Just push the power button and your ready to start playing!
Nov 28, 2013 | Nintendo Wii Console
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
I need to know which wires are what on a Clarion TVX5653 for the main(power) harness. There are 7 wires colored as follows red, yellow, black, blue, blue/yellow stripe,orange, orange/white stripe. Thank...
red is for pawer that goes to the fuse panel
black is for the ground
yellow is a hot wire that goes to the main power or battery it should have a fuse in the line
blue is for power antenna if u need
blue and blue yellow speakers same with orange ,orange/white
Dec 13, 2010 | Car Audio & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
How do i connect a telephone wire to an rj11 plug. What is the order of the wires for us telephones.
dialtone should go on the green and red wires of the jack for 1 line service, yellow and black for a second line.
Depending on the type of wiring that your dealing with the color code can change. if your wiring has white wires with little dashes of color on them then the code is:
green = white/blue (mostly white with blue dashes)
red = blue/white (mostly blue with white dashes)
black= white/orange (mostly white with orange dashes)
yellow= orange/white (mostly orange with white dashes)
Oct 23, 2009 | Lands Phones
I want to see the cheats of guitar hero2
Secret Guitars
  • Snaketapus Guitar: Complete Hard Mode.
  • The Log" Guitar: You must achieve 5-Star every song on Expert.
  • Battle Axe Guitar: Complete Expert Mode.
  • Casket Guitar: Complete Medium Mode.
  • Eyeball Guitar: You must achieve 5-Star every song on Hard.
  • Fish Guitar: Complete Easy Mode.
  • USA Guitar: You must achieve 5-Star every song on Easy.
  • Viking Guitar: You must achieve 5-Star every song on Medium.
Unverified. On the main menu, directly depress the colored key without any other input.
Performance Mode ... YELLOW, YELLOW, BLUE, YELLOW, YELLOW, ORANGE, YELLOW, YELLOW
Hyper Speed ... ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE, YELLOW
Air Guitar ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, BLUE
Eyeball Heads ... BLUE, ORANGE, YELLOW, ORANGE, YELLOW, ORANGE, BLUE
Moneky Heads ... ORANGE, BLUE, YELLOW, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Flaming head ... ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE, YELLOW, YELLOW
Horse head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE
Air guitar ... BLUE, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Eyeball Heads ... YELLOW, ORANGE, BLUE, ORANGE, BLUE, ORANGE, YELLOW
Hyper Speed ... YELLOW, ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE
Monkey Heads ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, YELLOW, BLUE, ORANGE
Flaming Head ... YELLOW, YELLOW, ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE
No HUD performance mode ... YELLOW, YELLOW, ORANGE, YELLOW, YELLOW, BLUE, YELLOW, YELLOW
Horse Head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE
To unlock everything in the game, insert the following code on your guitar at the title screen: Blue, Yellow, Orange, Red, Orange, Yellow, Red, Yellow, Red, Yellow, Red, Yellow.
Jun 05, 2009 | Video Game Consoles & Games
Akai PT5492S 54" Rear Projection Television Logo
193 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
