Question about Euro-Pro Shark 80 - 7133
Yet another stitch tension problem...
My sewing machine is either pulling the bottom thread straight and the top thread is looped, (so that it gathers when you pull the bottom thread) or the top thread is pulled taut and straight, and the bottom thread is pulled to the top, and shows ( so that it gathers when you pull the top thread).
My Brother BM-2600 did not come with instructions (some kind of mix up) or a bobbin case of any kind, so I don't even know if I need one!
I'm almost positive it is a stitch tension problem, but I don't know how to fix it, or even how to adjust the bottom tension. (Every so often it develops snarls of thread on the bottom. I think the bottom tension is too loose, but, I don't know how to fix that on my machine.)
  • 12 more comments
  • Vicktorianna Nov 25, 2007
    I do not have a bobbin case! Do you even read these problems before copying and pasting the same answer that I see everywhere?
    I said I didn't have a bobbin case, and no instructions. As a side note, I forgot to mention the 'tension discs' mean nothing to me.
  • Vicktorianna Dec 15, 2007
    I can sew, it's not impossible, assfuck. I do know how to use a sewing machine, FYI. I'm glad to see that you've figured out that you've been giving the wrong advice after 30 years of sewing. Maybe you should stick to a needle and thread too, if you can't even read the bloody question before popping in an innapropriate answer.
    Maybe someday you'll learn that people don't need a high-and-mighty helper.
    The instruction book wasn't sent with the machine, though it was supposed to be.
    If you expect it, why do you bother answering the stupid questions? Do you have nothing better to do with your time other than bother others with answers that don't help?
    I suspect you do a lot less sewing than you attempt to make others beleive.
  • Gary Turney
    Gary Turney Mar 25, 2008
    I've got a best built sewing machine and I want to know how to put the tension spring back on.
  • Anonymous Mar 13, 2014
    both the bottom and top thread do sew
  • Anonymous Mar 14, 2014
    I know this has something to do with tension? how do you adjust the tension so the threading is good?
  • Anonymous Mar 15, 2014
    the top thread tension pulls the bobbin thread completely thru to the surface on every stitch
  • Anonymous Mar 17, 2014
    bobbin thread is not even adjusted. the bottom thread is too loose
  • Anonymous Mar 19, 2014
    Tighten top tension to stop bottom loops and users material or gathers
    Top thread is tight and gathers material like it has elastic n t
  • Anonymous Mar 23, 2014
    show me different parts so that i can explain my problem
  • Anonymous Mar 28, 2014
    loops on bottom side
    bottom trhead not being pulled up
  • Anonymous Mar 30, 2014
    Top thread pulls strait out when doing patchwork
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Posted on Dec 14, 2007
Tension setting model lx2763how to set the tension top stitch looks good bottom stitch is loose
top tension is incorrect
pull the top thread out and there should be resistance to pulling it before you thread the needle
Nov 11, 2017 | Sewing Machines
Brother Sq9185 sewing machine, the thread on bottom just pulls out, when free motion quilting? how do I fix this
Sounds like the upper tension needs to be tightened, or the bobbin thread needs to be loosened. At any rate, the tension is correct when the two threads meet in the middle of the fabric for general sewing.
For free motion quilting, the tension should be adjusted so that the bobbin thread does not show on the top of the fabric, however, it should not lay in a straight line like it sounds like it may appear currently. What you are currently producing is a gathering stitch where the bobbin thread can be easily pulled.
Nov 16, 2015 | Generic Brother 130-Stitch Sewing and...
Bottom stitch is gathering, but I think the machine is not threaded correctly
I would start by re winding your bobbin and making sure that it is done though all the correct tension loops. A bobbin that is wound to tight or loose can cause all sorts of problems. If that has been done then completely rethread the machine from scratch. Now go through and check all your tensions, it sounds like the bobbin tension is too loose and your stitch tension is too tight. Adjust and try again.
Good luck
Feb 12, 2014 | Euro-Pro Shark Mini Mechanical Sewing...
What is the setting for gathering
Loosen the top tension until you see little loops on the bottom. Lengthen stitch length. Test first on scrap to get it down... sew a line then gather by pushing and pulling the bobbin thread. (don't pull it out!!)
Another way to do it without a special foot is to zig zag over a cord. :)
Once you have the gathers distributed... re-tighten the top tension and test on scrap again... then stitch your gathers in place.
Jul 20, 2012 | Sewing Machines
I altered the stitch to zigzag and now it wont stitch straight or anything!
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is not warped or damaged
adjust the top tension one number or letter higher till the stitch looks normal
if these suggestion don't help then the machine needs to be serviced
May 11, 2012 | Necchi Sewing Machines
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
May 25, 2009 | Juki HZL-E61 Computerized Sewing Machine
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Euro-Pro Shark 80 - 7133 Logo
533 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
