Question about Garmin GPS
I performed a hard reset but I don't have the password to a garmin nuvi 205w, what do I do?
  • Garmin Master
  • 2,130 Answers
If you set the password yourself, just go to the area (safe area) where you set it and the unit should unlock itself.Once unlocked, you can remove or change the pin. If you were not the one who set the pin, then you need to discuss the matter with who did or contact the factory. More info here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Posted on Aug 11, 2017
GarminJunkie
  • 50 Answers
SOURCE: how to register a garmin nuvi 205w
go to: https://my.garmin.com/mygarmin/marketing/register.htm
Posted on Jan 22, 2009
bunnydawg
  • 5158 Answers
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 02, 2009
SOURCE: Nuvi 205W keeps rebooting.
Here is the solution
touch the screen in the right bottom and turn the device on keep the screen pressed. when it asks to reset data select yes
Posted on May 16, 2009
the kowalski
  • 86 Answers
Your unit most likely has a firmware error, which could be due to a corrupt file. To solve it you yourself can try to update the firmware when connecting to the pc, if the unit cannot stay on enough for this to be performed, your unit will have to be sent in to service.
Posted on Jun 02, 2009
SOURCE: My garmin nuvi 205w will not boot past the loading
Yes, it's a software bug and the only way to fix it is to RMA it to Garmin and they will send you a new one. Waitin on my replacement now.
Posted on Jan 30, 2010
I have lost all maps and other features on my nuvi 205w
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device. This service will reload all native maps and features of your nuvi.
I hope that helps.
Feb 08, 2010 | Garmin nuvi 205W GPS Receiver
Tip
Hard Reset your Garmin Nuvi 205W (Mark 2b)
Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205W GPS Receiver
Tip
Perform a Hard Reset of your Garmin Nuvi 205 (Mark 2a)
Perform a Hard Reset of your Garmin Nuvi 205 and 205W
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205 GPS Receiver
My garmin will reset itself. I will lose all info when it does this.
Whenever Garmin Nuvi 205's start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Jan 21, 2010 | Garmin nuvi 205W GPS Receiver
Hi my garmin nuvi 205w has gone into some kind of reset loop. when i power on it shows the garmin logo, then loading maps, then does 2 beeps and shows the garmin logo again and repeats this sequence. any...
Try the Hard Reset procedure outlined in this tip.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 255W GPS Receiver
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205W Does your Garmin Nuvi...
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It is generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Your Favorites:
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
I hope that helps.
on Mar 22, 2010 | Baby Care
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W (Mark 2a
I hope that helps.
Garmin Nuvi will not load maps - why
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 205W GPS Receiver
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Tip
I hope that helps.
_______________________________________
Download Garmin Nuvi 205 Manuals here.
Garmin Nuvi 205 Favorites Backup here.
Garmin Nuvi 205 WebUpdater here.
on Jan 15, 2010 | Garmin nuvi 205 GPS Receiver
GPS Logo
54 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
