Question about RCA P52937 52" Rear Projection Television
Same problem, only with RCA model P61926
Bowed hour glass picture with colors out of sync. Mine is an intermittent problem. sometimes the picture is fine, sometimes it isn't. Are the problem components for my set the same as the one's listed for model P52937?
  • RCA Master
  • 3,459 Answers
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
same problem, only with RCA model P61926 - bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
Bowed in on both sides. colored lines everywhere
Open fuse/bad connections on HV ckt board and one or two bad capacitors.
Mar 22, 2010 | RCA D52W19 52" Rear Projection Television
I have rca 56wh78 56" with a bowed screen
You need to replace the FL231, DL231 and CP230 You can get the parts and instructions at the following link cost about 12.00 total. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 30, 2009 | RCA P52937 52" Rear Projection Television
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
RCA Model Number R52WM24
Is this a projection set? If so you simply need to set the convergence. Otherwise I would try to return it to the retailer and exchange for different manufacturer.
Apr 22, 2008 | RCA R52WM24 52" HDTV Projection Television
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
RCA Projection TV model #p61926
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
98 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
