Question about Epson Stylus CX4800 All-In-One InkJet Printer
I have an Epson Stylus CX4800 scanner. Problem: A 6-inch blackout occurs in the middle of the page. Will scan the outer edges of a document but the 6-inch center reflects multi-colors, but no image.
This sounds like a software problem. It might be best (and most simple) to just uninstall the epson software and then redownload and re-install it. Just log onto the Epson site and there will be helpful ideas and software there.
Posted on Sep 16, 2009
How do I scan a document to my computer
Just place the document in your scanner and use the software provided by your Epson Scanner.
Aug 12, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Is the Epson Stulus CX4800 a scanner, printer, copier?
Epson Stylus CX4800, is a all in printer. It can scan,copy and print. Thank You.
Jun 17, 2010 | Epson Stylus CX4800 All-In-One InkJet...
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
EPSON STYLUS CX4800
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
Feb 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Scanner Problem Epson Stylus CX4800
Try to clean the scanner glass with a dry cloth...
Try scanning afterwards...if the same issue occurs...
Try to uninstall and reinstall the scanner from your computer..
If you have windows...
Go to add or remove programs and uninstall "epson scan"
Apr 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Copy feature on Epson CX 4800 doesnt' work.
call epson and tell them your problem, the can help you, most of the time epson will replace the printer for you for free.
Nov 28, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson cx4800 1/2 inch good scan, rest is multicolor tweed
the only thing that comes to mind is maybe the cable is partially crimped and as the scanner moves the wires dont touch. otherwise, its possible there is an issue with a main board.
Oct 27, 2007 | Office Equipment & Supplies
Epson Stylus CX4800 All-In-One InkJet Printer Logo
177 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
