Question about GE Washing Machines
Washer does not spin even though water fill and drain properly. Water level presure swith working properly. How do you cehck the capacitor and the motor to make there is power get to each part. Washer is a GE top load cloth washer WSB312
    Problem Solver:
  • 13 Answers
OK,
This could be something not related to the electronics. The motor has a coupling that connects the output shaft to the transmission. If you can, check below the washing machine using a flashlight. If there is black rubber dust below the machine, that bushing needs to be replaced. It is worn out...The part is about $20 to $25 depending on where you purchase it.
To replace the coupling, drain the washer, then unplug the power. Tilt it back, then remove the motor to inspect the coupling. You can easily replace the coupling by removing the motor. There are two metal retainers that can easily be snapped loose using a large screwdriver. Pull the motor away from the transmission housing, then remove the existing coupling and install the new coupling.
Once it is in place, clip the motor back in place, tilt the washing machine back down, plug it back in, and VOILA! You are in business!
Posted on Jul 27, 2009
Samsung silvercare washer will not spin
How did you test the pump? These were my symptoms as well, and my pump was working intermittently. Sometimes, I could test the pump and it would work perfectly, and sometimes it would not work at all. Try running a load; the next time the machine won't spin, use the drain tube to drain water manually (I used a big shallow pan). There's a sensor in the washer that won't let spin start unless the water is below a certain level. In self-test mode, there's even a way to see what the machine is seeing as the water level. Anyway, let the water drain out manually with the drain tube; the machine should start spinning once the water is below the specified level. If the machine displays "Err" or "ND" before you have the chance to drain the water, you can hit pause once or twice and it will try to start the spin cycle again. To directly answer your question: If the machine will not start the spin cycle, it could be because the washer thinks the water level is not low enough to start the spin cycle. This could be because the water level is not low enough (ie a pump that's not working properly or a clogged hose), because the sensor that detects the water level is not working properly, or because the motherboard is malfunctioning. My discussion with a repair professional indicated that the pump is (by far) the most common culprit. I bought mine on Ebay very inexpensively (around $35, I think?). It is pretty quick and straightforward to disassemble the machine (check youtube for how-to videos). Just be careful -- they apparently used 2 different pumps more or less interchangeably on this model. Check if your pump is gray or black before ordering; I bought the wrong one. I made it fit because we needed the washer, but I ended up soldering the wires to the pump and re-routing some wires to make it work. It was a hassle. The electrical connector is different between the two pumps, so you'll be saving yourself a lot of hassle by ordering the right one.
Jun 01, 2014 | Samsung WF337AA Front Load Washer
Pressure switch?
sounds like you are having a syphoning issue. caused by having the drain hose too far down the home standpipe. very common problem. test..fill the machine, high water level. when it stops filling turn off. advance into spin/drain for just a moment and shut off. listen to hear water still going down the drain.
repair.. raise the drain hose nearer the top of the stand pipe. also do not tape/seal the hose into standpipe. it has to breath. good luck. kihm washing machine drain hose installation Google Search
Jun 13, 2017 | Maytag Washing Machines
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Water not pumping into dishwasher
I first checked the water valve in the dishwasher. It was working properly. The overflow or water level sensor had become stuck in the 'high level' position, thus telling the washer that it was already full of water. I corrected that and it began working properly. As for water in the bottom of the dishwasher that didn't seem to be draining completely - I turned the timer to a point in the cycle where it would drain, making sure I turned the washer off before it cycled back to the 'fill or rinse' cycle. I think the water had accumulated because of the timing of the cycles getting out of sync with the water level in the washer.
Jan 06, 2009 | Dishwashers
Will not run wash properly
The sensor you are referring to could posslbly be the water level switch which controlls the level of water,and also. is a factor as to wether the washer will spin or not, it also is part of the heater circuit, so it has numerous functions.
I t can be found at the top right front of the washer, and is about 3" in diameter, and has a thin plastic tube going to it.
it could be sticking, there is no sure fire way of testing it properly, but you could try tapping it and blowing down the tube, it may solve the prob.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint WMA50 Front Load Washer
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
