Question about Corel Video Studio Pro X2 for PC
In Video Studio Pro I can not save downloaded TV signal, nect time I open the Movie Wizard to record TV signal I have to scan all channels again and I can not save the TV signal, signal is cable from Foxtel, please advise, thank you, Vlad
    Guru:
  • 519 Answers
I would like to share you a best converter i have used:
Video Download Studio
Click here to see the full reviews and have a free trial:
http://www.downloadvideos-convert.com/download-videos-music
It can convert almost any the video format to another with high output quality.
This full-featured video converter software also can help you:
1.convert between all mainstream video and audio formats,such as(mp4, mov, m4v, vob, XviD, avi, flv, 3gp, 3g2, mpg,wmv,etc;m4v, mp3, wav, ac3,etc)
2.extract audio tracks from video files to other audio formats
3.support all popular portable multimedia players
4.edit video-Merge, Trim, Crop and Snapshot
It is very easy to use,just follow the instructions on it you can convert your videos and make your movies and music taken easily on PSP, PS3, iPod, iPhone, Apple TV, Xbox or other digital devices.
Hope this can help you.
Posted on Jun 30, 2010
Dazzle DVD recorder software does not save my video properly
You don't say where you are trying to save it to. Try saving it to the default location on you desktop hard drive and then transfer it to your phone.
Sep 15, 2012 | Pinnacle Dazzle DVD Recorder
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
Accessing and recording schebuled TV video.
You were not too clear on the problem, but if you mean playback, then a very good program is PowerDVD. It will access the files stored (Pinnacle and other capture devices, store the files as .mpg typed, NOT DVD .vob files.) Software like AVS video Converter, can create the DVD formatted disks; trial is free download.
Jul 23, 2009 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
Samsung lcd tv is saying low or weak signal when trying to tune it in
you can only use your tv to scan for channels with an antenna or if you have that tv hooked to cable television. use your Directv receiver to scan for channels, if you have an antenna hooked up to it. --------------- click this link for more help http://www.highdefforum.com/directv-forum/77638-new-lcd-tv-d-sd-no-weak-signal.html thaNKS.
Jul 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Make movie keeps timing out, render error
I have also been running into an MPEGENCODER.DLL error about 1/2 way through my 20 minute movie. I am able to Make Movie with a 6 minute version, but hitting this error time and time again. I have removed Virus protection and all unessential system tray loads; defragged drive; downloaded newest Windows drivers; downloaded newest NVIDIA drivers; running Win XP Pro SP3, Intel 3GHZ, 1GB RAM, 76GB/10K spin drive.
Jul 01, 2009 | Pinnacle Studio Plus 12 for PC
Pc freezes during making movie in progress
I think computer crash in this reasons computer might turn to hibernate mode or screen saver is activated.
Or the computer start scanning for viruses and downloading process for the updates.
I suggest to disable all thus process before you start then try it again.
Jun 25, 2009 | Pinnacle Studio Ultimate 12 for PC
Wintv stuttering when watch channel, but is fine when record it
Further update: Have downloaded SageTV, and it works fine with the Hauppage card. Is definitely a software problem. Have also tried total uninstall, reinstall, with same results. Also downloaded GBPVR, and it also worked with the card.
Jan 03, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Corel Video Studio Pro X2 for PC Logo
134 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
