Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LG LFX25960SW Refrigerator--Display goes bizerk
Purchased refrigerator in April 2007--within two weeks and numereous times since then, the display goes bezerk. Everything lights up, all numbers are "8's" except the room temperature display which is "188". The display is locked up, nothing works. This lasts anywhere from three to ten minutes. This happens right after or during the time I have dispensed ice and chilled water. I hear three beeps and then everything lights up. I noticed one time that the compressor also started at the same time, this may have happened others times but I didn't notice it. I also have noticed on several occasions that the compressor stops and the display is back to normal. Anybody else have the problem?
  • erbeck Aug 16, 2009
    The circuit board in the display has been replaced a week ago. So far so good, but only time will tell.
    Champion:
  • 363 Answers
It is going thru a diagnostic process, But this is only to happen when you either open the circuit board and press the test button, or use the front display keypads. I would have the circuit board checked
Posted on Jul 30, 2009
Service mode for Maytag MFX2570AEM3 refrigerator
How to enter service test mode in a Maytag refrigerator with electronic controls
Service Test Mode:
The service test functions are performed using the refrigerator display and keypad.
Enter the Service Test Mode by performing the following sequence of events.
1. Open the Fresh Food door and press and hold the Door Alarm keypad DoorAlarm .
2. Press and hold Refrigerator Temperature UP keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. Press the Refrigerator UP Keypad again.
5. Display will show 001 in left display and numeric or dashes in right display.
6. Press Freezer Up keypad and Freezer Down keypad to toggle through Service Test numbers.
hope this helps.
also may find more info at repairclinic.com site
Jan 10, 2018 | Maytag Washing Machines
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
The display panel shows OF and now it's not getting cold in either the freezer or frig.
he letters "OF" on the display of your RS267TDRS indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and a numeric reading returns to the display, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Our lg refrigerator/freezer has a frozen freezer fan. How do I defrost it without unplugging the whole refrigerator? Can I use a hair dryer and if so, where is the fan in the freezer? Thanks for your...
You could take the small cover off the back, then press the small switch on the motherboard 3 times, which manually puts the refrigerator into defrost for about 10 minutes. Refrig will beep a 3 beep tone and display all threes in display.
Apr 27, 2011 | LG Refrigerators
I have an LG LFX25960SW - 3 door refrigerator. I installed the water hose connected from my faucet and 15 minutes later I got "ER IF" on my display panel. I've unplugged my refrigerator for a few hours and...
the IF erroR is for the ice fan in your freezer it is not working properly or is froze up the control can detect problems with the fan i would check to see if it is running and jammed but it is verabal speed so if it ant jameed there is a good chance you need an ice fan
Jun 03, 2010 | LG LRFD25850 French Door Refrigerator
Door display shows ER WITH A UPSIDE DOWN HP. I turn the power off and back on and the display goes back to normal but after several hours it goes back to where the only thing on the display is the ER PH...
That stands for "error defrost heater"
Even though the refrigerator has gone through a defrost cycle, if a temp sensor does not reach a set temp within an hour, that error will display. You may have a bad defrost heater, defrost relay, thermal fuse, blocked defrost drain,..... something wrong with the defrost system anyway.
Aug 03, 2009 | LG LFX25960ST Stainless Steel French Door...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer fan motor replacement
you must take out plastic inside where the freezer create lowest temperature
May 12, 2009 | LG LFX25960 Bottom Freezer French Door...
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
436 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
