Question about 3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk)
Trying to enable IP Sec on 3 com router
I need to get into my settings on my router to enable the IP Sec. I have heard there is a universal ip address of some sort for 3 com routers that will let you into the settings to change them but I cant' find it. Any one know how to enable the IP Sec for a 3 com router from your computer?
    Scholar:
  • 193 Answers
  • Default Username / UserID: admin (lowercase only, or try leaving it blank)
  • Default Password: admin (lowercase only, or try leaving it blank)
  • Default IP Address: 192.168.1.1 or try or try 192.168.2.1
  • and go to to wire less>and search for VPN and there u have these option>and rate me solved if its helps thx
    Posted on Nov 25, 2007
    My ip adress says unavailable
    Sounds like the computer you're trying to connect to your wi-fi router is set up with a static IP address that is being reserved by your router for DHCP. To resolve, make sure your router has "DHCP" (dynamic host configuration protocol) turned on. Make sure the computer you're trying to connect to your router is set up to allow the DHCP server in your router to set the computer's IP address and DNS server address. You can find instructions to enable DHCP in your router's user manual or by searching online. You can find instructions for setting your computer's wireless adapter to allow the DHCP server in your router to set the computer's IP and DNS addresses here:
    http://www2.wolfson.cam.ac.uk/files/IT/Settings_for_DHCP_for_Windows.pdf
    Jan 07, 2014 | Computers & Internet
    I'm using dlink di-634m router, now i'm trying to block facebook but i don't know how. i tried using schedules, firewall setting but still my staff can get access to it.
    Step 1 Open a web browser and type the IP address of the DI-624M in the address bar (default is 192.168.0.1). Press Enter.
    Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK.
    Step 3 Click the Advanced tab at the top and then click Parental Control on the left side.
    Step 4 Select Enabled below URL Blocking and configure the following:
    • URL String - Enter a domain name (such as microsoft.com)
    • Start IP - Enter the first IP address to apply URL Blocking to
    • End IP - Enter the last IP address to apply URL Blocking to
    Step 5 Click Apply to save the new settings.
    If you need more help come back.Post / thumbs / testimonial are welcome!
    Nov 20, 2010 | D-Link DI-634M Wireless Router (DI634M)
    I am trying to install my netgear Universal Wifi Range Extender WN2000RPT. I have green lights for my connection to the router, the extender is on and it is connected to the main PC. But I only have...
    For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
    Nov 10, 2010 | NetGear Computers & Internet
    Can't connect to my linksys wrt54gx2 router and even when I do, it tells me there is an ip address conflict and disconnects me
    try to connect using a LAN Cable (Wired) connection. and then try to access 192.168.0.1 you should be able to see wireless settings there.
    IP address must not be the same with the IP Address of other computers in your house. look for the Range and Increase it so that the router could have a wider range of IP Address to choose from.
    Oct 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
    2 xboxes on one router
    This is a NAT/Port/IP issue....
    1. jump on a computer, run cmd and then ipconfig/all
    2. note the IP address, subnet mask and default gateway.
    3. jump on you xbox, go to system settings, network settings, configure network, IP settings.
    4. Pick manual then change:
    -the ip address to a varient of your ip address. Eg, if you ip address is 192.168.0.9, then make the ip address of the console eg 192.168.0.91 or 192.168.0.92 etc
    -the subnet bank to the same as noted from ipconfig/all
    -the default gateway as the same as the chosen ip address.
    5. Ensure DNS Settings are set to automatic.
    Changes to router (how to take these steps will depend on your router):
    -Ensure the DNS ip address is given automatically by the isp, same with the internet ip address.
    -NAT is enabled.
    -port forward ports 53, 80, 88, and 3074.
    -change mtu to about 1500.
    May 08, 2010 | Microsoft Xbox 360 Console
    IP address invalid
    8360169.jpg music studio 12 deluxe installed correct on vista openns to studio but wont finish loading computer locks if i click on any tabs ???
    Dec 18, 2009 | Computers & Internet
    I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
    To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
    1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
    If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
    2. Install the HP printer driver on your computer/s using the LPT printer port.
    3. Connect the printer with a LAN cable to the network hub/router.
    4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
    5. Click on Ports and click on Add Port.
    6. In available ports - click on Standard TCP/IP Port and then Configure port.
    7. Tick the IP box and type in the IP address of the HP's printer IP address.
    8. Click OK and tick Enable bi-directional support and then OK
    Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
    Do a test print page to check the printer.
    You can now print from any computer on your network.
    Dec 03, 2009 | 2wire Computers & Internet
    I have a Netwave Base G4 wireless router w/ 4- port switch,trying to network two computers via cable modem using local ports,modem and router not communicating
    You need to change the LAN IP address of your router. Open the router's admin through http://192.168.1.1 and look for router's IP address or Local IP Address. Change it to 192.168.10.1 and save the settings. Reboot the router after that. If you are on cable internet , you need to do MAC Cloning. Access the router's admin page and look for MAC Clone settings. Enable and clone the PC's Mac Address. Save the settings and power cycle the router and the modem after that.
    Aug 02, 2009 | Blitzz Technology (BWA611) Router
    VPN passthrough
    What are the settings that you have for your netgear router? Its going to tunnel, right? Try this solutions and see it will work.
    1. Access the set-up page of the router, from a browser, type 192.168.1.1
    2. Go to VPN tab and select IP SEC VPN
    3. Local Security Group, set it to subnet and input the Network Address of the router (LAN IP - 192.168.1.0)
    4. Remote Security Group, set it to subnet and input the Network Address of the netgear router (LAN IP, for example - 192.168.2.0)
    5. Remote Secure Group, set it to IP only, WAN IP address of the netgear router
    6. For Key Managemnt, just make sure that all settings are identical with the netgear router
    7. Last go to Advanced Settings and make sure that group settings are identical to the netgear router
    Hope it works for you
    Jun 24, 2008 | Linksys RVS4000 Router
    Unable to get my WET54G up and running
    Make sure that you routers IP range is setup to handle the IP address of your PC.
    Feb 02, 2008 | Linksys Wireless-G WET54G 802.11g/b...
    3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk) Logo
    111 people viewed this question
    Top 3Com Computers & Internet Experts
    micky dee
    didi2005
    Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
