Question about Clarion DB175MP CD Player
I need help getting my radio to turn on after i got a new battery
I had to put a battery in my car now my radio donot work i replace the fuse what can i do its it a on and off switch i have a clarion db175 mp in a 1994 honda accord ex
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 94 Answers
I assume you checked at the fuse block of the car. If the radio is aftermarket also check if it has has a fuse or maybe 2 fuses at the radio. They might be in fuseholders from the hot wires of the radio.
Posted on Jul 27, 2009
I have a 1995 gmc sierra c1500 and the radio in it stopped working. The last time I drove the truck it worked perfectly fine then somebody left my key turned so my battery died. I recharged the battery...
You also have a fuse in the fuse box that is for the radio is the radio the only thing that is not working because sometimes there are more than one fuse that controls the radio
Mar 04, 2015 | GMC Cars & Trucks
How do you check fuse in the back of the radio?
1.Turn off the vehicle. Locate the main fuse box.
2.Locate a fuse box that isn't under the dashboard by checking under the hood of the car.
3.Look at the diagram on the inside of the fuse box's cover.
4.Determine if the fuse is blown by looking through the clear plastic casing.
5.Take the blown fuse to an electronics store or a car-parts store.Push the new fuse into the empty slot in the fuse box, making sure that it is in the same direction as the other fuses. It should slide in with a tight fit.Replace the fuse-box cover.
6.Complete the above steps before removing the car radio.Disconnect the car battery under the hood by disconnecting the cable from the negative terminal (the black cable) of the battery. Remove the dash area around the car radio.Unscrew the four screws on each corner of the car stereo.Locate the fuse on the back of the car radio.
7.Take the blown fuse to a car-parts store or electronics store to find a replacement fuse. Place the new fuse into the car radio.lide the car radio back into the dash opening. Replace the corner screws followed by the dash trim panels. Put any screws and clips back into place.Reconnect the car battery. Turn the car on, and if the blown fuse was the problem, the radio should work.
OBD diagnostic tool one stop supplier
Jun 03, 2014 | 2001 Volkswagen Beetle
Dash clock and radio will not turn on--HELP
The radio has three hot wires yes three, one is always hot this keeps the clock and your preset stations. one comes on when you turn the radio on and one comes on for a powered ant or an amp. Plus some radios have a ground wire and also ground through your ant. check all theses. And if you still can not get it going come by.
Feb 26, 2014 | 2003 Hyundai Tiburon
Clarion NZ500 nothing on screen
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Aug 22, 2017 | Clarion NZ500 Car Video Player
The battery in my valkswagen died and when it was charged back up my raido stoped working what do i do?
you will need to find the security code for radio and put put that in for radio to start working again
if it is factory radio most car makers put a sticker in glove box that only has some numbers on it and no other info - that is usually the radio unlock code
if it is aftermarket radio it might be stuck into the owners manual - which will also tell you procedure for putting that code into radio
only other thing i could think of is that a fuse for radio has blown
good luck
Mar 24, 2011 | Clarion CZ209 Car CD USB MP3 Player
I cant put in mu codes for my clarion car radio
Leave it SWITCHED ON...UNDISTURBED until it resets itself
Dec 07, 2009 | Clarion Car Audio & Video
Radio
sounds like the radio failed internaly you would have to replace the radio and when you put new one in make sure its secure and not over heating
Jun 01, 2009 | 2005 Ford Focus
Clarion DB175MP CD Player Logo
258 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
