Computers & Internet Logo
I just got this targus not too long ago and ive been trying to figure out if jm doing something wrong or irs broken. I got the targus chill mat+ with usb and i plugged it into the wall for a min but i dont hear the fans working. I plugged it into the computer and still hear no fans. Am i doing something wrong or is it broken i dont really know how to work it
5 Related Answers
Anonymous
  • Posted on Jun 03, 2009
SOURCE: targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Anonymous
  • 3153 Answers
  • Posted on Sep 17, 2009
SOURCE: Cruzer Micro USB Flash Drive ReadyBoost not working
PLEASE TAKE NOTE OF ITEM 3
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Testimonial: "Thanks. Saw this posting earlier & checked & corrected the issues you described, as much as I could. Still having problems. "
steve_e_uk
steve morris
  • 1675 Answers
  • Posted on Oct 02, 2010
SOURCE: Lost the targus notebook chill
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Anonymous
  • 10406 Answers
  • Posted on Oct 30, 2010
SOURCE: My 17 " Targus chill
Ignore the messages -- you connect it to draw electrical power through the USB port, and that's all you need. It's not like some USB-devices (printers, scanners, et cetera) where getting power to the device is only "half" of the solution.
Anonymous
  • 811 Answers
  • Posted on Apr 06, 2011
SOURCE: Hi! I have the Targus
I did some research and found your product and replacement parts are Click Here Thanks for using FixYa! John
1helpful
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
How do I get the additional usb ports to work on targus awe0101us1 chill pad
Does your laptop recognize the extra USB ports? If no, try updating your drivers.
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
I bought this Targus Chillmat 8 months ago and when I plug in the USB, it seems like only half of the fan is working. The chord that attaches to the USB port to plug into the laptop looks broken, but I'm...
A USB has only 2 power wires, the outer ones onpin 1 and pin 4, which is 5 VDC. The two inner pins 2 and 3 carry data only, which can't power a fan.
As part of the cooler is working it is more likely a fan problem.
21helpful
3answers
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
2helpful
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Power cable problems, also
open it up and splice the current power cable and connect it permanently to the USB connector. The problem is the power plug gets loosened after some time and can't make a proper connection.
2answers
Chill mat
i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
